01-11-2017 06:27 PM - edited 03-17-2019 09:09 AM
Has anyone migrated from VG224/248 to VG350 and know the issues will be
01-11-2017 10:52 PM
Hi Zulfi,
You can check these details in the Hardware Installation guides of both these products here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/vg248/1_0/english/install/guide/hard_ins/vg248hwi.html#wp1021316
http://www.cisco.com/c/en/us/td/docs/routers/access/vg350/hardware/installation/guide/vg350_hig.pdf
Manish
01-11-2017 10:55 PM
We did migrate to 320. We kept the cabling as it is (disconnect analog distributed panel from 224 and moved it to 320 as it is), looked at the old cable mapping and new cable mappings, finally migrated the DNs from old schema to new schema accordingly to maintain seemless experience to the users.
01-12-2017 12:04 PM
Thanks for your feedback.
So the Telco Connectors from VG248 stays same when we move to VG350
