CUCM to H323 Dial Peer not working
Salvo_Phl
Hi All,
I have a customer with a remote site located in India. I have configured an H323 Gateway on the CUCM.
Incomming calls work perfectly.
When I attempt to make an outgoing call, I receive a fast busy tone.
This is the outbound dialpeer:
dial-peer voice 10 pots
description National Calls
destination-pattern .T
port 0/2/0:15 - (The PRI port is up and operational as I can receive calls)
IND-SR-RTR01#sh controllers e1
E1 0/2/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
The correct dialpeer is being reached:
IND-SR-RTR01#debug  voice dialpeer all
voip dialpeer all debugging is on
<output ommited>
Nov 30 12:18:36.952: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=10Nov 30 12:18:36.952: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
The result of a debug h225 asn1 is:
IND-SR-RTR01#debug h225 asn1
H.225 ASN1 Messages debugging is on
IND-SR-RTR01#
Nov 30 12:25:10.214: H225.0 INCOMING ENCODE BUFFER::= 20B0060008914A00050201803733401F0030003400300030000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010480C9B94C438B000097A0950F2161ED2600AF02AC14221A00D50D80000700AC14010B06B811000097A0950F2161ED2600AF02AC14221A010001000100010010A001000F0140B5000012088144000400010300
Nov 30 12:25:10.214: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body setup :
          protocolIdentifier { 0 0 8 2250 0 5 }
          sourceAddress
            dialedDigits : "0400",
            h323-ID : {"0400..."}
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              productId '436973636F43616C6C4D616E61676572'H
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          destinationAddress
            dialedDigits : "9686191058"
          activeMC FALSE
          conferenceID '0097A0950F2161ED2600AF02AC14221A'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip 'AC14010B'H
            port 1720
          callIdentifier
            guid '0097A0950F2161ED2600AF02AC14221A'H
          mediaWaitForConnect FALSE
          canOverlapSend FALSE
          multipleCalls FALSE
          maintainConnection FALSE
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '8144000400010300'H
Nov 30 12:25:10.214: H225 NONSTD INCOMING ENCODE BUFFER::= 8144000400010300
Nov 30 12:25:10.214: H225 NONSTD INCOMING PDU ::=
value H323_UU_NonStdInfo ::=
      callMgrParam
        interclusterVersion 3
        enterpriseID {}
Nov 30 12:25:10.218: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          protocolIdentifier { 0 0 8 2250 0 4 }
          callIdentifier
        h245Tunneling FALSE
Nov 30 12:25:10.218: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A0004110011000097A0950F2161ED2600AF02AC14221A10800100
If anyone can assist as to what the problem can be, that would be greatly apprecieated.
I have attached the current router config with the relavant lines in it.
Thanks in advance.
Phil
8 Replies 8
acampbell
Phil,
Looking at the dial peer 10
This will forward all digits including the 9
Try changing to
destination-pattern 9T
Alex
Regards, Alex. Please rate useful posts.
Hey Alex,
The 9 is actually part of the full number that needs to be dialed, so it is not a preceeding digit needed to access the PSTN.
Philip.
Can you provide the output from
debug isdn q931
For the failed call.
Rgeards
Alex
Hi Phillip, I suggest to configure the *h323-gateway voip bind srcaddr IP ADDRESS* under the interface that is registered as H323 GW in your Callmanager.
hth
David
Hi Alex,
No output displayed from debug isdn q931, but there is output from debug h225 asn1 as specified above.
Hi David,
I have added that command but still no joy.
Thanks all for the help with all so far...
Phil
try adding "no digit-strip" into the dial-peer 10 and post debug output if call fails.
debug isdn q931
debug isdn q921
deb voice ccapi inout
deb h225 as
deb h245 as
Phil,
Looking at the H225 trace I dont think we are matching an inbound dial peer from VOIP
The IP address is sourced from AC14010B(HEX) = 172.20.1.11
Can you add this dial peer (Just for testing)
dial-peer voice 101 voip
preference 2
incoming called-number .
destination-pattern 0...$
session target ipv4:172.20.1.11
voice-class h323 1
dtmf-relay h245-alphanumeric
Try another call
Alex
Hi All,
Thanks for all of the replies.. I managed to sort out the problem with the help of TAC. Below are the details.
1. First problem was as suggested by Alex, there was no inbound dial peer to match the incomming VOIP leg form the CallManager. This was the Dial-Peer configured :
dial-peer voice 99 voip
session target ipv4:172.20.1.10
voice-class h323 1
2. Secondly, the service provider in India required the calls to be passed in ascending order from channel #1 and not the default descending order from Channel #31. The following command was added:
interface Serial0/2/0:15
isdn bchan-number-order ascending
3. Lastly , there has been a new feature added to the newer IOS versions for Toll Fraud prevention that requires IP addresses of incomming VOIP calls (SIP or H323) to be trusted. It is enabled by default and is disabled with:
voice service voip
no ip address trusted authenticate
Thanks again.
Phil
