Yes it matters. You can't install on SUB if not installed in PUB even if in
inactive partition. Now in your particular scenario it might work as you
are in the main train. Check the compatibility matrix.
Also, I suggest don't reboot after installation. Make sure that you
complete installation on all inactive partitions then reboot.
