07-21-2011 01:20 AM - edited 03-16-2019 06:03 AM
I am looking to update the software revision on our CUCM Cluster. I am currently running on 7.0(2a) and would like to confirm if the highest direct revision I can get to is 8.0(3a)? Then as far as I can see from 8.0(3a) i can get up to 8.6(1a). I have not done a CUCM upgrade before so just want to be sure I am reading the tables right.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp349495
Additionally, I am unsure of hardware requirements for the newer versions.
The current hardware is:
HW Platform : 7835H2
Processors : 1
Type : Intel(R) Xeon(R) CPU 5140 @ 2.33GHz
CPU Speed : 2333
Memory : 2048 MBytes
HDD :2x 146GB
I read on another post that more recent versions need 4GB of RAM, is that the case?
Franco
Solved! Go to Solution.
07-21-2011 02:06 AM
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html is your friend.
GTG
07-21-2011 02:06 AM
GTG
07-21-2011 03:08 AM
Thanks Gordon,
Do you know with regards to upgrading the RAM, can I buy pretty much any make i.e. Corsair in order to upgrade it to 4Gb- as loong as it is "PC2-5300 667-MHz DDR2 synchronous dynamic RAM (SDRAM) Fully Buffered DIMMs"
07-21-2011 03:53 AM
I'm not sure about Cisco's official line on this, but I suspect:
- If your box is under hardware support by Cisco then you'll need to have genuine Cisco/HP memory in there.
- If you don't have maintenance on the box, do what you like.
GTG
