CUCM - Utils capf cert import fails with parse error
admin.dsi
Im working on CUCM . I and im not a phone system administrator. I mean i m not experienced in this solution.
I'm trying to secure phones on the network with 802.1x auth. For that, Im asked to upload Windows CA certificates to Cisco IP Phones. And I can't make it work :/
Let me explain.
I have a CUCM (Publisher ? ), the main one.  And I have a second CUCM  (subscriber ? ), wich is a backup, and on wich phones registers.
I have followed a Cisco guide here : https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118779-configure-cucm-00.pdf
I have uploaded my Windows CA chain as CallManager-trust purpose (Root > Intermediate > Device CA).
I've set the "Offline CA" parameter and restarted the CAPF service.
My phone is configured to Install/Upgrade CAPF and now in "Operation Pending"
I am able to generate a CSR
utils capf csr count
Count CSR/Certificate files. Valid CSR : 1 Invalid CSR : 0 Certificates: 0
I m able to issue a certificate for this CSR in CER format, before renaming to DER format. (2048 bits key)
The file is compressed with Linux into TGZ format.
Then, Im trying to upload the certificate to CUCM, but it fails
utils capf cert import
Importing files.
Source:
 1) Remote Filesystem via FTP
 2) Remote Filesystem via TFTP
 q) quit
Please select an option (1 - 2 or "q" ): 1
File Path: mycertificate.tgz
Server: xxx.xxx.xxx.xxx
User Name: johndoe
Pwd: ************
Certificate file imported successfully
Certificate files extracted successfully.
Please wait. Processing 1 files
Parsing for certificate mycertificate.der failed.
As you can see, my certficate does not work, and I don't know why.
How can i troubleshoot this ? Please help me with detailed steps, as im not comfortable with all CUCM environnement/commands/tools.
Thank you.
Edit :
Following guides, Ive been able to get the logs files. I have reproduced the import, with failure, and here are the logs. That looks like missing something. Not telling me anything helpful :(
file get activelog cm/trace/capf/sdi/capf*.txt
13:58:50.453 | debug ERROR:Inside sigusr1 catcher
13:58:50.453 | debug ERROR:Read certificates and post messages
13:58:50.454 | readSignedCert Certificates in the directory are:
admin.dsi
Ok.
Issue fixed after re issuing another certificat. I think it was an export format mistake.
admin.dsi
Ok.
