CUCM , Voice Gateway and RIGHT FAX
Dear All
We have integrade voice gateway with right fax via h323 protocol
The issue now is that if one internal fax client want to sent a fax to another internal right fax client then the fax going through voice gateway to the pstn and coming back...withe results internal faxes to be charged
Now we cant dial 4 digits number for right fax client but a full geografical number
If we integrade CUCM with Right FAx then the internall faxes will go internally or no?
Is possible to dial a 4 digits(fax clients have 4 digits) and reach the other internal fax client ?
regards
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Marwan ALshawi
Rightfax had something similar to cucm route patterns ti send the call
So you can create a dial plan on the right fax too
Hope this help
Plz rate the helpful posts
Marwan ALshawi
Yes sure you can use internal extent ion numbers as the call controll will be on the CUCM and CUCM has to know where the fax number located if it is noted registered to CUCM via ATA or vg22xx
But just becarful when you integrate with the right fax using sip trunk check the inbound and outbound sip using tcp or udp as they must match with fax server side you can edit it in the sip profile setting and assign it to the sip trunk if you gonna use sip
Hope this help
If helpful rate
hi
i am thinking to use H323 protocol for the integration between CUCM and Right Fax
So Right fax can not controll by its self the extension numbers that are assign to it?
Its need it CUCM for that right?
do you have any usefull dogumentation
Thank you for the answer and your help
regards
chrysostomos
RightFax can route faxes to itself without ever touching the Cisco environment.  You just need to create a four digit dialing rule that receives faxes back into the RightFax server.
Chad Derrington
Services and Support Manager
Ingenium Software
Marwan ALshawi
Hope this help
