11-01-2017 12:24 PM - edited 03-17-2019 11:31 AM
I have the CUCM 10 and i want to integration with ASTERIK, the ASTERIK is the Gateway for the another extension. I configure que SIP trunk fot the port 5060, for the PSTN Calls the Asterik is the Gateway.
In the CUCM the SIP trunk is UP, but when dialing trougt the SIP trunk the call was done but there is no audio in the call.
Did someone go through the same case?
or What configuration did you used?
11-01-2017 12:50 PM
Take a look at the steps here - https://www.uccollabing.com/2014/05/16/cucm-asterisk-trunk-integration/
Brandon
11-14-2017 12:14 PM
i did the configuration but it did not work, the same problem.
11-15-2017 09:39 PM
Are you inserting any media device such as xcoder. If not are you phones able to ping the pbx.
