01-13-2011 02:12 AM - edited 03-16-2019 02:50 AM
Morning all, I'm stuck on a problem that I can not find a way around at the moment without editing every user profile.
We have CUCM 7 working which integrated into our AD so all end users are already associated with CCUM, I need to set up 90 users with extension mobility which I have done through BAT, the problem is I do not what the default PIN number is that is already in the field under end user section.
I understand that I can BAT all the users to get the PIN changed but it would be a lot easier if I knew what was already used by default.
Martyn
Solved! Go to Solution.
01-13-2011 02:29 AM
Martyn,
You can just update the users Pin using a Bulk Admin, Users, Reset Password/Pin and use a query or custom file to select the user group.
Hope this helps,
Craig
01-13-2011 02:29 AM
Martyn,
Hope this helps,
Craig
01-13-2011 03:24 AM
Nice one, looks like I just just query by department which will help me.
Thanks for the reply
Martyn
01-13-2011 02:35 AM
Default pin is 12345
01-13-2011 03:25 AM
I'm pretty sure that I have tried 12345 before which did not work, I have a BAT to do
later and I will let you know if 12345 works.
Martyn
