IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5652 Views
  • 14 replies
I need to find which network ports to open on an ACL to allow MOH to pass through.  Currently, on our wireless network, I am able to route RTP properly between endpoints, but MOH can not be heard (MOH is configured properly, it works fine on the wire...
Hi,    When 7960 is turned on, the  Headset, Mute and Speaker buttons slow flash in sequence after which the screen continues to show configuring VLAN along with UNIVERSAL APPLICATION LOADER.I have tried everything from pressing # to 123456789*0# whi...
Hello Everyone, i have a issue with a Call Manager 7.0.2, i hope you can help me...I Have one central site and one remote...also have several route patterns that i used for the calls on both sides..I have a particular route pattern used for emergency...
Resolved! Outgoing DDI
We have a PBX -> QSIG->2900->CUCM8->ISDN2900GATEWAY.I would like to display DDI number when making calls over the PSTN  (this is from the PBX handsets and Ip Phones)as opposed to the main number. I know you can do it on the phones. but I want to do i...
pcromwell by Level 3
  • 507 Views
  • 4 replies
