CUCMBE - CUCM Upgrade vs Unity
I am new to CUCMBE, I saw in the SRND that CUCM and Unity use the same file for the upgrade.
I am running 8.0.2 and I want to go to 8.5.1.
If I upgrade CUCM, is it gona automaticly upgrade Unity connection ? if not how do I upgrade Unity
Jaime Valencia
That's correct, when you upgrade a CUCMBE you upgrade both CUCM and CUC.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Hello Jaime,
so , if i have a version : 8.5.1.10000-26
and need to move to version like : 8.6 ... or 8.5 SU6 .. I should normally download the same file from cisco as if iam upgrading the CUCM only ? ...
and is their any consideration when doing that update ? .. I have done many updates but for CUCM and CUC separately ...
Thanks in advance for your help ..
Ahmed Salah
If you have CUCM-BE 5K   it's one upgrade that will do both
If you have CUCM-Be6K  this is like a full call manager and a full unity, so you need to do the upgrade on cucm and then on unity,
For the consideration, do yourself a backup for CUCM/Unity
regards,
