01-18-2013 01:23 AM - edited 03-16-2019 03:14 PM
Before I call TAC, just wondering if anybody else has seen this issue.
CUCMBE 8.6.2.23048-1 ES.
DRS Backups fail with the message
Failed to initiate backup. Server [CUCM], component [CLM] requires component [PLATFORM] to be registered.
Looking at the registered components, I have this:
UCM | CUCM | CCMPREFS |
UCM | CUCM | CCMDB |
UCM | CUCM | CLM |
UCM | CUCM | BAT |
UCM | CUCM | MOH |
UCM | CUCM | ANN |
UCM | CUCM | REPORTER |
UCM | CUCM | TFTP |
UCM | CUCM | CEF |
CDR_CAR | CUCM | CAR |
CONNECTION_GREETINGS_VOICENAMES | CUCM | GREETVN |
CONNECTION_DATABASE | CUCM | DATABASE |
CONNECTION_MESSAGES_UNITYMBXDB1 | CUCM | MESSAGES |
CUC | CUCM | PLATFORM |
So, no "UCM" and "PLATFORM" - which is obviously the issue. Reading around folks have fixed this by restarting DRF master and local; I've tried this multiple times with no luck. I've even rebooted the whole server.
RTMT and logs are my next stage, but just wondering if anybody else had any ideas.
Barry Hesk
Intrinsic Network Solutions
01-18-2013 01:39 AM
Think this is the problem in the DRF Local Service. Now, just need to work out how to fix it... The DRF Local logs are full of these.
DEBUG [drfLocalRegMonitorThread] - CheckDeRegistrationFiles: Processing ... null_PLATFORM_deregister.xml
2013-01-18 07:51:38,118 INFO [drfLocalRegMonitorThread] - drfUtils:ReadXMLObject: File: /common/drf/null_PLATFORM_deregister.xml
2013-01-18 07:51:38,119 INFO [drfLocalRegMonitorThread] - CheckDeRegistrationFiles: AutoRegistered Component:true
2013-01-18 07:51:38,119 INFO [drfLocalRegMonitorThread] - drfLocalWorker.HandleDeRegistrationReq: Received de-registration request
2013-01-18 07:51:38,119 ERROR [drfLocalRegMonitorThread] - drfLocalWorker.HandleDeRegistrationReq: Feature name is empty
2013-01-18 07:51:38,119 ERROR [drfLocalRegMonitorThread] - drfLocalRegMonitor.run: caught exception [null]
java.lang.NullPointerException
at com.cisco.cpi.drf.drfLocalWorker.HandleDeRegistrationReq(drfLocalWorker.java:542)
at com.cisco.cpi.drf.drfLocalRegMonitor.CheckDeRegistrationFiles(drfLocalRegMonitor.java:262)
at com.cisco.cpi.drf.drfLocalRegMonitor.run(drfLocalRegMonitor.java:91)
2013-01-18 07:51:48,122 INFO [drfLocalRegMonitorThread] - CheckDeRegistrationFiles: There are 7 DeRegistration files
2013-01-18 07:51:48,123 DEBUG [drfLocalRegMonitorThread] - CheckDeRegistrationFiles: Processing ... null_PLATFORM_deregister.xml
2013-01-18 DEBUG [drfLocalRegMonitorThread] - CheckDeRegistrationFiles: Processing ... null_PLATFORM_deregister.xml
2013-01-18
01-18-2013 06:44 AM
Working with TAC now. DRS is officially very broken and my engineer is currently "ls"ing and "grep"ing. Will post more details when it is sorted.
Barry Hesk
