10-03-2011 05:24 AM - edited 03-16-2019 07:17 AM
Customer is currently running CUCMBE ver. 6.1(5) and will be upgrading to 8.6(1a). The compatibility guide indicates this is a supported direct upgrade and have acquired media and licensing via PUT.
The release notes for 8.6(1a) indicate an external USB storage device is required during this upgrade since the customer's hardware is a MCS7828H3-K9-BE:
For HP7825H3/HP7828H3 hardware:
This server model requires a USB storage device in order to proceed with the upgrade. Please insert a USB storage device with at least 16GBytes of capacity. Note that any existing data on the USB device will be deleted.
Note: For Unity Connection and Business Edition the USB storage device must be 128 GBytes.
Are there any other equirements re: the external device, it's size, parttioning, formatting, etc.?
Does it need to be a USB flash drive or will an external hard drive work?
Does it need to be 128GB exactly or will larger drives work?
Does it need to be partitioned and formatted in any particular way, or will the upgrade procedure do this for me?
Can anyone who has performed an upgrade like this using the external drive comment on the success, failure or "gotchas" associated with the external drive?
Thank you.
Solved! Go to Solution.
10-05-2011 11:45 AM
i did an update from CUCM 8.0 to 8.6.1 last night and this should be the same procedure. So here the answers to your questions based on my experience....
NO
external hard drive works fine, i used a platinum 500Gb usb 3.0 hard drive.
no problem detected with larger drive as mentioned above...
the setup process mounts and formats the drive automatically, then it transfers install image and database tables to the drive, reboots the server and performs a fresh install of the whole system. During the install procedure the database tables are converted and populated to the new system...
I performed this update on two CUCM clusters each with a pub and a sub and we have had no problems... Before starting the upgrade process be sure that the ciscocm_refresh_upgrade software package is installed on the server. This package can be downloaded from CCO (CUCM --> CUCM 8.6 --> Utilities) . I guess the upgrade procedure is the same regardless of software version (CUCM or CUCMBE).
regards,
Martin
10-05-2011 11:45 AM
NO
regards,
Martin
08-22-2012 09:23 AM
When following the same procedure to upgrade a cluster, do I need the external HD for both PUB and SUB? I have this question because the PUB and SUB servers are located in defferent cities ans I like to make sure the external HD is ready if it's required for SUB as well.
Thanks.
Michael
