CUCME & CUE (ISM) integration (AA not functioning)
I have a client with ISR 2901 . A cucme (Software Version  15.2(3)T1 / CME 9.0  ) with CUE (Cisco Unity Express - Administration Version 8.6.1)
is configured.
The following is cucme configuration for CUE
"Interfaces configuration"
interface ISM0/0
ip unnumbered GigabitEthernet0/1.10
service-module ip address 172.16.10.3 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 172.16.10.1
interface GigabitEthernet0/1
description "Connected to BOM-SW1 Gig0/24"
no ip address
no ip redirects
no ip proxy-arp
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1.10
description "Voice Sub Interface"
encapsulation dot1Q 10
ip address 172.16.10.1 255.255.255.0
ip route 172.16.10.3 255.255.255.255 ISM0/0
Dial-Peer-Config for Unity
dial-peer voice 800 voip
description <Unity#555autoattendent>
destination-pattern 555
session target ipv4:172.16.10.3
voice-class codec 1
dtmf-relay h245-alphanumeric
ip qos dscp cs3 signaling
no vad
dial-peer voice 808 voip
description (autoattendentUnity#555-sip)
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 222 voip
description <ICM-CUE>
destination-pattern 554
session target ipv4:172.16.10.1
voice-class codec 1
no vad
Voice-Ports Configuration
voice-port 0/1/0
trunk-group BOM-OUT
supervisory disconnect dualtone mid-call
timeouts interdigit 3
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 500
connection plar opx 555
description <Ph.No. 013390>
caller-id enable
voice-port 0/1/1
trunk-group BOM-OUT
cptone GB
timeouts interdigit 4
impedance complex2
description <Ph.No. 030191>
bearer-cap Speech
caller-id enable
Unity Express Configuration
groupname Administrators member administrator
groupname Broadcasters privilege broadcast
username Receiptionist phonenumber "101"
restriction msg-notification create
restriction msg-notification min-digits 1
restriction msg-notification max-digits 30
restriction msg-notification dial-string preference 1 pattern * allowed
calendar biz-schedule systemschedule
closed day 1 from 00:00 to 24:00
open day 2 from 08:00 to 17:00
open day 3 from 08:00 to 17:00
open day 4 from 08:00 to 17:00
open day 5 from 08:00 to 17:00
open day 6 from 08:00 to 17:00
closed day 7 from 00:00 to 24:00
end schedule
ccn application autoattendant aa
description "autoattendant"
enabled
maxsessions 2
script "welcome.aef"
end application
ccn application ciscomwiapplication aa
description "ciscomwiapplication"
enabled
maxsessions 10
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "8001"
parameter "strMWI_ON_DN" "8000"
end application
ccn application msgnotification aa
description "msgnotification"
enabled
maxsessions 10
script "msgnotify.aef"
parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
parameter "DelayBeforeSendDTMF" "1"
end application
ccn application promptmgmt aa
description "promptmgmt"
enabled
maxsessions 1
script "promptmgmt.aef"
parameter "appManagementScript" ""
end application
ccn application voicemail aa
description "voicemail"
enabled
maxsessions 10
script "voicebrowser.aef"
parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
end application
ccn engine
end engine
ccn reporting historical
database local
description "se-172-16-10-3"
end reporting
ccn subsystem email
end subsystem
ccn subsystem fax
end subsystem
ccn subsystem sip
gateway address "172.16.10.1"
end subsystem
ccn trigger http urlname msgnotifytrg
application "msgnotification"
enabled
maxsessions 2
end trigger
ccn trigger http urlname mwiapp
application "ciscomwiapplication"
enabled
maxsessions 1
end trigger
ccn trigger sip phonenumber 555
application "autoattendant"
enabled
locale "en_US"
maxsessions 2
end trigger
ccn trigger sip phonenumber 554
application "voicemail"
enabled
maxsessions 4
end trigger
service phone-authentication
end phone-authentication
service voiceview
enable
end voiceview
voicemail broadcast recording time 300
voicemail default messagesize 240
voicemail notification restriction msg-notification
voicemail operator telephone 101
The Call from outside is hitting on Voice Port 0/1/0 or 1 and hitting Dial-peers for CUE :"PLAR555".
But welcome message is not getting played.
Please need support for this case.
6 Replies 6
mahmoodmkl
Level 7
Level 7
Hi.
I think u only need 1 dail-peer for AA and u r missing the below from the first dial-peer.
Thanks for your support.
I have included this command but still same result.
Do you think I need any more configuration on CUE!!
Thanks for this.
I have follow it. But issue is same.
it is not working.
Do u think we need to make any specific configuration change on CUE?
I have found that if i call from local extension to AA # 555. the dp 800 or 808 is matched but only phone show 555 aa line busy
status.
what its mean?
The issue is resolved.
On unity i had to give command to activate license for mailbox.
This enable license for aa .
