CUCME question
wilsonp70
I have a CUCME 9.5 and I am unable to save the config from the GUI. I get the message other telnet session active.
I seem to remember this was a bug in earlier versions is this the case in 9.5.
ronpatel
Level 8
Level 8
I am not sure how is this bug. As far as I know this is working as design.
-Used  command show users, find the telnet sessions.
-Do a clear line < > , in order to delete those sessions.
-Added the following commands also:
1)exec-timeout 10   ( telnet session will be disconnected after 10 min of inactivity)
2)logout-warning 60 (60 sec before automatically logging off router will send warning
message to user to save config)
-Reload the router.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Thanks I will try what you suggest. I did find a bug for earlier version. I will let you know how it goes.
