IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5814 Views
  • 14 replies
Hi,Until now all the sites used u-law where i worked. I have a requirement where one country telco uses a-law standard. Is there any configuration that i need to put in place on the VG to support a-law or the ISDN PRI does the voice encoding
Hi I have a CUCME 9.5 and I am unable to save the config from the GUI. I get the message other telnet session active. I seem to remember this was a bug in earlier versions is this the case in 9.5.
wilsonp70 by Level 1
  • 246 Views
  • 2 replies
HII all, I Have set up mobility profiles for metting rooms, and are workign fine the problem is I do not have an option to logout of the profile once signed in I am using Cisco IP Phone 7940 series. I must be missing a setting somewhere can somebody ...
Running Unity Connection 8.6.2.I set up a call handler to serve as my auto attendant for the office.  I configured caller input '5' to leave a message and send the message to a user with a mail box.  The user receives these messages, but they do not ...
