CUCME - SIP/2.0 482 Loop Detected to viatalk
Djurre Woudstra
Hi All,
I'm trying to setup call manager express with via talk and i'm able to do an out bound call, but get disconnected after 30 second with a "SIP/2.0 482 Loop Detected" error.
Any help is greatly appreciated
Kind regards
DJ
version 15.3
service nagle
service tcp-keepalives-in
service tcp-keepalives-out
hostname MED-DC-UCME01
boot-start-marker
boot system flash:/c3900e-universalk9-mz.SPA.153-3.M6.bin
boot-end-marker
aqm-register-fnf
! card type command needed for slot/vwic-slot 0/0
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
ip dhcp excluded-address 10.227.35.1 10.227.35.10
ip dhcp pool vlan35-voice
network 10.227.35.0 255.255.255.0
default-router 10.227.35.1
dns-server 10.227.10.20 192.168.1.21
option 150 ip 10.227.35.4
lease 7
ip cef
no ipv6 cef
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 10.1.1.1
ipv4 66.147.235.3
ipv4 174.133.67.154
ipv4 173.231.3.114
ipv4 216.120.237.24
ipv4 192.168.11.40
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface BVI255
bind media source-interface BVI255
registrar server expires max 250 min 200
outbound-proxy dns:bumblebee.vtnoc.net
no call service stop
voice class codec 1
codec preference 1 g729br8
codec preference 2 g711ulaw
codec preference 3 g711alaw
codec preference 4 g729r8
voice register global
mode cme
source-address 10.227.35.4 port 5060
load 7941 SCCP41.9-2-1S
load 7941GE SCCP41.9-2-1S
load 7942 SCCP42.9-2-1S
load 7961 SCCP41.9-2-1S
load 7961GE SCCP41.9-2-1S
load 7962 SCCP42.9-2-1S
authenticate register
tftp-path flash:
create profile sync 0086021255010478
voice hunt-group 1 parallel
final 2004
list 2009,2004
timeout 20
pilot 2000
voice translation-rule 1
rule 1 /9911/ /911/
rule 2 /9411/ /411/
voice translation-rule 2
rule 1 /9+/ //
voice translation-rule 3
rule 1 /9[2-9]........./ /1/
voice translation-rule 4
rule 1 /91+/ /1/
voice translation-rule 5
rule 1 /9011+/ /011/
voice translation-rule 6
rule 1 /178xxxxxxxx/ /2009/
voice translation-rule 7
rule 1 /9+/ //
voice translation-profile Incoming
translate calling 7
translate called 6
voice translation-profile International
translate calling 7
translate called 5
voice translation-profile Local10
translate calling 7
translate called 3
voice translation-profile Local7
translate calling 7
translate called 2
voice translation-profile LongDistance
translate calling 7
translate called 4
voice translation-profile Services
translate calling 7
translate called 1
license udi pid C3900-SPE250/K9 sn FOC18500YE4
license boot module c3900e technology-package securityk9
license boot module c3900e technology-package uck9
license boot module c3900e technology-package datak9
hw-module pvdm 0/0
file privilege 0
redundancy
track 100 ip sla 100 reachability
class-map match-all L3-to-L2_VoIP-Cntrl
match ip dscp af31
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
class-map match-all SIP
match protocol sip
class-map match-all RTP
match protocol rtp
policy-map output-L3-to-L2
class L3-to-L2_VoIP-RTP
set cos 5
class L3-to-L2_VoIP-Cntrl
set cos 3
policy-map EthOut
class RTP
bridge irb
interface GigabitEthernet0/0
no ip address
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2.11
encapsulation dot1Q 11
bridge-group 11
interface GigabitEthernet0/2.35
encapsulation dot1Q 35
bridge-group 35
interface GigabitEthernet0/2.255
encapsulation dot1Q 255
bridge-group 255
interface GigabitEthernet0/3
no ip address
duplex auto
speed auto
interface GigabitEthernet0/3.11
bridge-group 11
interface GigabitEthernet0/3.35
bridge-group 35
interface GigabitEthernet0/3.255
bridge-group 255
interface BVI11
ip address 10.227.11.4 255.255.255.0
ip nat inside
interface BVI35
ip address 10.227.35.4 255.255.255.0
ip nat inside
interface BVI255
ip address 12.x.x.x 255.255.255.248
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:/cmegui
ip route 0.0.0.0 0.0.0.0 12.x.x.x
ip route 10.0.0.0 255.0.0.0 10.227.11.1
ip route 192.168.0.0 255.255.0.0 10.227.11.1
ip access-list standard remote-ssh-in
remark ----ssh in from cayman office----
permit 10.0.0.0 0.255.255.255
permit 172.16.0.0 0.15.255.255
permit 192.168.0.0 0.0.255.255
permit 74.x.x.x 0.0.0.7
ip access-list standard rfc1918-no-nat
deny 10.0.0.0 0.255.255.255
deny 172.16.0.0 0.15.255.255
deny 192.168.0.0 0.0.255.255
permit any
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:/phoneloads/7941-7961/apps41.9-2-1TH1-13.sbn alias apps41.9-2-1TH1-13.sbn
tftp-server flash:/phoneloads/7941-7961/cnu41.9-2-1TH1-13.sbn alias cnu41.9-2-1TH1-13.sbn
tftp-server flash:/phoneloads/7941-7961/cvm41sccp.9-2-1TH1-13.sbn alias cvm41sccp.9-2-1TH1-13.sbn
tftp-server flash:/phoneloads/7941-7961/dsp41.9-2-1TH1-13.sbn alias dsp41.9-2-1TH1-13.sbn
tftp-server flash:/phoneloads/7941-7961/jar41sccp.9-2-1TH1-13.sbn alias jar41sccp.9-2-1TH1-13.sbn
tftp-server flash:/phoneloads/7941-7961/SCCP41.9-2-1S.loads alias SCCP41.9-2-1S.loads
tftp-server flash:/phoneloads/7941-7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phoneloads/7941-7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phoneloads/7940-7960/P0030801SR02.bin alias P0030801SR02.bin
tftp-server flash:/phoneloads/7940-7960/P0030801SR02.loads alias P0030801SR02.loads
tftp-server flash:/phoneloads/7940-7960/P0030801SR02.sb2 alias P0030801SR02.sb2
tftp-server flash:/phoneloads/7940-7960/P0030801SR02.sbn alias P0030801SR02.sbn
tftp-server flash:/phoneloads/7940-7960/P0030801SR02.txt alias P0030801SR02.txt
tftp-server flash:/phoneloads/7942-7962/apps42.9-2-1TH1-13.sbn alias apps42.9-2-1TH1-13.sbn
tftp-server flash:/phoneloads/7942-7962/cnu42.9-2-1TH1-13.sbn alias cnu42.9-2-1TH1-13.sbn
tftp-server flash:/phoneloads/7942-7962/cvm42sccp.9-2-1TH1-13.sbn alias cvm42sccp.9-2-1TH1-13.sbn
tftp-server flash:/phoneloads/7942-7962/dsp42.9-2-1TH1-13.sbn alias dsp42.9-2-1TH1-13.sbn
tftp-server flash:/phoneloads/7942-7962/jar42sccp.9-2-1TH1-13.sbn alias jar42sccp.9-2-1TH1-13.sbn
tftp-server flash:/phoneloads/7942-7962/SCCP42.9-2-1S.loads alias SCCP42.9-2-1S.loads
tftp-server flash:/phoneloads/7942-7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phoneloads/7942-7962/term62.default.loads alias term62.default.loads
control-plane
bridge 11 protocol ieee
bridge 11 route ip
bridge 35 protocol ieee
bridge 35 route ip
bridge 255 protocol ieee
bridge 255 route ip
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 32
associate application SCCP
dial-peer voice 20 voip
description Incomming SIP CAY->MED
session protocol sipv2
session target ipv4:10.1.1.1
session transport udp
incoming called-number 2...
voice-class sip bind control source-interface BVI11
voice-class sip bind media source-interface BVI11
codec g711ulaw
ip qos dscp cs5 media
ip qos dscp cs4 signaling
dial-peer voice 21 voip
description Outgoing SIP MED->CAY
destination-pattern 8...
codec g711ulaw
dial-peer voice 10 voip
translation-profile outgoing Services
destination-pattern 9[49]11
session target dns:bumblebee.vtnoc.net
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 11 voip
translation-profile outgoing Local10
destination-pattern 9786[2-9]......
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 12 voip
translation-profile outgoing Local7
shutdown
destination-pattern 9[2-9]......
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 13 voip
translation-profile outgoing LongDistance
destination-pattern 91[2-9]..[2-9]......
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 14 voip
translation-profile outgoing International
destination-pattern 9011T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 15 voip
description Viatalk Voicemail
destination-pattern *123
codec g711ulaw
dial-peer voice 17 voip
description Unblock CallerID information
destination-pattern *82
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 18 voip
description Call Back The last incoming caller
destination-pattern *69
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 19 voip
description Broadcast Menu/Record Broadcast Messages
destination-pattern *400
dtmf-relay rtp-nte
codec g711ulaw
gateway
sip-ua
authentication username 178xxxxxxxx password 7 05xxxxxxxxxxx
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers register 250
mwi-server dns:bumblebee.vtnoc.net expires 300 port 5060 transport udp
registrar dns:bumblebee.vtnoc.net expires 300
sip-server dns:bumblebee.vtnoc.net
host-registrar
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 4
sdspfarm transcode sessions 10
sdspfarm tag 1 HWCONF
conference hardware
video
max-ephones 32
max-dn 128
ip source-address 10.227.35.4 port 2000
max-redirect 20
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
time-zone 13
max-conferences 8 gain -6
web admin system name admin secret 5xxxxxxx
dn-webedit
transfer-system full-consult
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
night-service day Sun 17:00 08:00
night-service day Mon 17:00 08:00
night-service day Tue 17:00 08:00
night-service day Wed 17:00 08:00
night-service day Thu 17:00 08:00
night-service day Fri 17:00 08:00
night-service day Sat 17:00 08:00
fac standard
create cnf-files version-stamp 7960 Feb 18 2016 14:38:10
ephone-dn 1 dual-line
number 2001
label 2001
ephone-dn 2 dual-line
number 2002
label 2002
ephone-dn 3 dual-line
number 2003
label 2003
ephone-dn 4 dual-line
number 2004
label 2004
ephone-dn 5 dual-line
number 2005
label 2005
ephone-dn 6 dual-line
number 2006
label 2006
ephone-dn 7
ephone-dn 9
number 2009 no-reg primary
label 2009
name DJ's Test phone
hold-alert 30 originator
ephone 1
device-security-mode none
mac-address 0023.331B.77E7
button 1:1
night-service bell
ephone 2
mac-address 0023.339B.102D
button 1:2
ephone 3
mac-address 0023.331B.C815
button 1:3
ephone 4
mac-address 0021.A02D.EFF5
button 1:4
ephone 5
mac-address 0023.331B.C9AF
button 1:5
ephone 6
mac-address 0023.EB53.94E1
button 1:6
ephone 7
mac-address 0050.56A5.EF0D
type CIPC
button 1:9
line con 0
line aux 0
line vty 0 4
timeout login response 300
privilege level 15
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
scheduler allocate 20000 1000
ntp update-calendar
ntp server 129.6.15.30 prefer
ntp server 132.163.4.102
end
Djurre Woudstra
Debug
Feb 19 20:19:34.152: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x2B6BA190) with key=[23214] to table
Feb 19 20:19:34.152: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Feb 19 20:19:34.152: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Feb 19 20:19:34.152: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Feb 19 20:19:34.152: //28231/000000000000/SIP/State/sipSPIChangeState: 0x2B6BA190 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/critical/32768/ccsip_ipip_media_forking_read_from_TDContainer: MF: Unable to read data from TD Container..
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/critical/32768/ccsip_ipip_media_forking_forked_leg_config: MF: TD container cannot be read/container is NULL. Setting of forked call leg failed..
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 1, Event Id: EV_UNDEFINED
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: IWF Event: E_SIP_IWF_EV_SET_MODE
Feb 19 20:19:34.152: //28231/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_MODE
Feb 19 20:19:34.152: //28231/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/ccsip_get_int_type_frm_set_mode_ev:
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/is_mode_sip_sip_md_snr:
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/is_mode_sip_sip_ed_snr:
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/is_mode_sip_sip_md:
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/is_mode_sip_sip_ed:
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/is_mode_sip_h32x_in_set_mode:
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/is_mode_sip_h323_in_set_mode:
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/is_mode_sip_sccp_in_set_mode:
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/8192/sip_iwf_def_set_mode_hdlr: Setting SPI mode to SIP-TDM
Feb 19 20:19:34.152: //28231/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_sccp_early_dialog_container
Feb 19 20:19:34.152: //28231/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/ccsip_iwf_handle_peer_event: Return value: SIP_IWF_SUCCESS
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: CC_EV_IF_DIAG_DONE
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: IWF Event: E_SIP_IWF_EV_SET_FLOW_MODE
Feb 19 20:19:34.152: //28231/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_FLOW_MODE
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/is_fa2ft_md_flow_mode_transition:
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/is_fa2ft_flow_mode_transition:
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/ccsip_get_flow_mode_frm_set_flow_mode_ev:
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/verbose/4096/ccsip_iwf_process_event: IWF - cnfsm ret 2
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
Feb 19 20:19:34.152: //28231/000000000000/SIP/Info/info/4096/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_call_setup_request: Number Translation Set For Called-Number
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:34.152: //-1/xxxxxxxxxxxx/SIP/Info/verbose/5120/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : bumblebee.vtnoc.net target_port : 5060
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/4096/sipSPIUaddccCallIdToTable: Adding call id 6E47 to table
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/notify/131072/ccsip_call_setup_request: Incrementing call counter to [1] in dial-peer [13]
Feb 19 20:19:34.152: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Feb 19 20:19:34.152: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/2049/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec bytes: 0
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/2048/sipSPI_ipip_store_config_info: Setting mid_call_config_info = 0x0 for callid = 28231
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/8192/sipSPIGetCallConfig: Media forking disabled
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/32768/sipSPIGetCallConfig: Media Antitrombone disabled
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/notify/131072/sipSPICanSetFallbackFlag: Local Fallback is not active
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/8192/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/2304/sipSPISetMediaFlowMode: xcoder high-density disabled
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/8192/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/4/update_video_params_from_config: Checking Video Type Rate=-1 video_codec_allowed=1F
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/12288/sipSPIGetModemInfoPerCall: peer_callID=28230
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/critical/32768/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/8704/sipSPIGetCallConfig: Incoming: No defer BYE for last
call stats
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/34816/ccsip_ipip_media_forking_anchor_leg_config: MF: en_p->encap_s.voIP.voipPeerCfgMediaClass = 0
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/critical/34816/ccsip_ipip_media_forking_anchor_leg_config: MF: Dial-peer has no media class recorder.
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/36864/sipSPIMFChangeState: MF: Prev state = 0 & New state = -1
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/32768/ccsip_ipip_media_forking_anchor_leg_reset: MF: Anchor leg config reset done...
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/32768/ccsip_ipip_media_forking_intra_frame_request_config: MF: FIR en_p->encap_s.voIP.voipPeerCfgMediaClass = 0
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/critical/11264/ccsipInitDSCPPolicyInfo: No DSCP Profile configured, No RPH 2 DSCP Mapping and DSCP policing
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/8192/sipSPIGetCallConfig: Initilise the DSCP policy
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/8192/sipSPICheckFAAnatAssymetricOrDO2EO: Not a SIP-SIP call or not in FA mode
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/notify/8192/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/10240/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/2048/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/notify/10240/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/5120/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/1/preprocessSetup:
This is a not a SIGO Call -, could be DM call
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_INIT_CALL_SETUP
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_iwf_process_event: IWF - cnfsm ret 2
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/notify/4096/preprocessSetup: SIP-TDM or TCL/VXML app case
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/notify/4096/sip_gw_pre_setup_update_stream_media_direction: peer_callID = 28230
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/critical/4097/sip_gw_pre_setup_update_stream_media_direction: peer_channels/stream is NULL
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/notify/1/sip_gw_pre_setup_add_sdp_container: DNS/ENUM resolution required; Deferred Creating SDP
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacUpdateAccountedBw: bwcac update accounted BW Option 0 flow mode flow-through
audio bw 0 bps video bw 0 bps fax bw 0 bps total bw 0 bps accounted bw 0 bps
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacUpdateInterfaceBw: bwcac acquiring interface BVI255 bw 0
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacUpdateAccountedBw: bwcac update accounted bw (initial offer) accounted bw set to 0
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/133120/sipSPIBwCacIsDialPeerBwAvailable: bwcac NOP dial-peer bw available tag 13
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/notify/1/sipSPIBwCacIsInterfaceBwAvailable: bwcac interface bw threshold not configured
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacVerifyBwThreshold: bwcac verify bw threshold, bw available allow call total bw 0 bps
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/critical/8192/sipSPIValidateGtd: Signal Forward disabled
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/critical/8192/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/critical/10240/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/3072/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/9216/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/4096/sipSPIAddPrivacyandIdentityInfo: ccb->local_host_name,ccb->src_addr_str is NULL
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/critical/2048/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Error/sipSPI_ipip_set_history_info_header:
Feb 19 20:19:34.152: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/State/sipSPIChangeState: 0x2B6BA190 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_SENT_DNS)
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/State/sipSPIChangeState: 0x2B6BA190 : State change from (STATE_IDLE, SUBSTATE_SENT_DNS) to (STATE_IDLE, SUBSTATE_SENT_DNS)
Feb 19 20:19:34.152: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/ccsip_get_ifaddress: ip_address IPv4 12.1.2.3 for SIP
Feb 19 20:19:34.152: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 12.1.2.3 for SIP
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: signaling bind address : 12.1.2.3
Feb 19 20:19:34.152: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 12.1.2.3
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/4096/sipSPIUaddCcbToUACTable: ****Adding to UAC table.0x2B6BA190 ECC8824B-D67C11E5-B418DD4E-41EF9C4A@12.1.2.3
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x2B6BA190 key=ECC8824B-D67C11E5-B418DD4E-41EF9C4A@12.1.2.3 balance 1
Feb 19 20:19:34.152: //28231/EB59E1D3B413/SIP/Info/verbose/12288/sipSPIUsetBillingProfile: sipCallId for billing records = ECC8824B-D67C11E5-B418DD4E-41EF9C4A@12.1.2.3
Feb 19 20:19:34.152: //-1/xxxxxxxxxxxx/SIP/Info/notify/8192/sip_dns_type_srv_query: TYPE SRV query for _sip._udp.bumblebee.vtnoc.net and type:1
Feb 19 20:19:34.180: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sip_dns_type_srv_query: Server Name bumblebee.vtnoc.net
Priority 0 Weight 1 Port 5060
Feb 19 20:19:34.180: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sip_dns_type_srv_query: Server Name soundwave.vtnoc.net
Priority 1 Weight 1 Port 5060
Feb 19 20:19:34.180: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sip_dns_type_srv_query: Server Name ratchet.vtnoc.net
Feb 19 20:19:34.180: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sip_dns_type_srv_query: Server Name slingshot.vtnoc.net
Feb 19 20:19:34.180: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sip_dns_type_srv_query: Calculating Random Number : 26686 factor 65535 value 0
Feb 19 20:19:34.180: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sip_dns_type_srv_query: Selected Server is bumblebee.vtnoc.net
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/notify/8192/sip_dns_type_a_query: TYPE A query successful for bumblebee.vtnoc.net
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sip_dns_type_a_query: ttl for A records = 177 seconds
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sip_dns_type_srv_query: IP Address of bumblebee.vtnoc.net is:
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sip_dns_type_srv_query: 66.147.235.3
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sip_dns_type_srv_query: ttl for SRV records = 623seconds
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 43
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/State/sipSPIChangeState: 0x2B6BA190 : State change from (STATE_IDLE, SUBSTATE_SENT_DNS) to (STATE_IDLE, SUBSTATE_NONE)
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPICacheHostToCCB: sipSPICacheHostToCCB dnsResponse.num_hosts = 1
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPICacheHostToCCB: IP Address No. 1, IP address 66.147.235.3
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/ccsip_get_ifaddress: ip_address IPv4 12.1.2.3 for SIP
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 12.1.2.3 for SIP
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: signaling bind address : 12.1.2.3
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 12.1.2.3
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIRscmsmAvail: Value returned by check is = 0
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/critical/2048/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/critical/1024/sipSPI_ipip_set_history_info_header: No HI header recvd from container
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/verbose/8192/sipSPIAddPrivacyandIdentityInfo: Removing "id" value from Privacy
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: peer_tag=13
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 12.1.2.3
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/critical/1/sipSPIOutgoingCallSDP: Failure in creating outbound streams
SIP: (28231) Group (a= group line) attribute, level 65535 instance 1 not found.
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 19606 for stream 1
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/1/sipSPIDoBearerCapToCodecMapping: Bearer capability to Codec Mapping: DISABLED
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/131074/sipSPIBwCacCalcMaxAudioBandwidth: calculating max bw from preffered codecs (local offer)
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/131074/sipSPIBwCacCalcMaxAudioBandwidth: max bw (excluding pak overhead) from preffered codecs: codec g711ulaw bw 64000 index 0
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/critical/2/sipSPIBwCacCalcMaxAudioBandwidth: audio caps channel idx not found !!!!
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/131074/sipSPIBwCacCalcMaxAudioBandwidth: max bw (including pak overhead) from preffered codecs: codec g711ulaw bw 80000
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/notify/8193/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/1/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_IDLE
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacUpdateAccountedBw: bwcac update accounted BW Option 5 flow mode flow-through
audio bw 80000 bps video bw 0 bps fax bw 0 bps total bw 80000 bps accounted bw 0 bps
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/139264/sipSPIBwCacUpdateInterfaceBw: NOP (no interface change)
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacUpdateAccountedBw: bwcac update accounted bw (no interface change)
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 66.147.235.3,Port 5060, Transport 1, SentBy Port 5060
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:2F93A130
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/8192/Session-Timer/sipSTSLSRReqSend: Session timer is not required
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Configured SE:1800, Configured Min-SE:1800
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 0 event
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_offer_ans_handle_sent_sdp:
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_SENT
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_offer_ans_is_invite_offer_valid: TRUE
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_offer_ans_common_offer_sent_hdlr:
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_iwf_handle_network_event:
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SENT_SDP
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/4096/is_sent_sccp_do_video_inactive:
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/4096/is_mode_sip_sccp_do_video:
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/4096/sip_iwf_def_ed_sent_sdp_offer_hdlr:
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_SENT
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/sipSPIgetRegistrarHost: registrar host retrieved : bumblebee.vtnoc.net
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/critical/4096/ccsip_ipip_media_forking_get_forked_recording_data: MF: Not a Forked leg..
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/critical/1024/sipSPICreateRecParticipantHeaders: X-Cisco-Recording-Participant header not added.
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/34816/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendInvite: Associated container=0x2F93A130 to Invite
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 277
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x245391FC, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x4F5026C
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x2B6BA190 with connection=0x24D9EACC context list
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x245391FC
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x245391FC, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/512/sentInviteRequest: Sent Invite in state STATE_IDLE
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sentInviteRequest: Transaction active. Facilities will be queued.
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/State/sipSPIChangeState: 0x2B6BA190 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_SENT_INVITE, SUBSTATE_NONE)
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/verbose/6/sipSPIAddStream: set stream_callid from ccb->ccCallID:0x6E47, media_type:0
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 28231) to the VOIP RTP library
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/1/sipSPIAssignStreamCallId: Assigning streamid 28231 to stream 1. Old streamid = 28231
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/8192/sipSPIUpdateRtcpSession: ccb->flags != LOOPBACK
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Media/sipSPIUpdateRtcpSession: Setting do_rtcp = FALSE 0
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 12.1.2.3, lport = 19606, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
src_callid = 28231, dest_callid = -1, stream type = voice+dtmf, stream direction = SENDRECV
media_ip_addr = - , vrf tableid = 0 media_addr_type = 1negotiated_bandwidth (kbps) = 0 srtp_services = 0 nat_flag = 0
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/verbose/1/sipSPICreateRtpSession: sess: 220713D4 do_rtcp:0
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Media/sipSPICreateRtpSession: stun is disabled
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/critical/131072/sipSPIUpdateRtcpSession: Not able to Associate DSCP Profile with GCCB dscp_policy = 0x0, IS_SIPSPI_MODE_IN_SIP_SIP = 0 dscpPolicySeviceBlock = 0x0 , stream->qos_info = 0x0
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: Voice quality monitoring is not enabled for this RTP session due to sdp passthru enabled
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=28231
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/notify/2080/sipSPIUpdateRtcpSession: DTMF inb/oob disabled
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/State/sipSPIChangeStreamState: Stream (callid = 28231) State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Info/info/2/sipSPIUpdateCallEntry:
Call 28231 set InfoType to SPEECH
Feb 19 20:19:34.182: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
Feb 19 20:19:34.182: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:18662966457@bumblebee.vtnoc.net:5060 SIP/2.0
Via: SIP/2.0/UDP 12.1.2.3:5060;branch=z9hG4bK798C11E1
From: "DJ's Test phone" <sip:200@bumblebee.vtnoc.net>;tag=B8F1A5F4-1DF9
To: <sip:18662966457@bumblebee.vtnoc.net>
Date: Fri, 19 Feb 2016 20:19:34 GMT
Call-ID: ECC8824B-D67C11E5-B418DD4E-41EF9C4A@12.1.2.3
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3948536275-3598455269-3021200718-1106222154
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M6
All
Feb 19 20:19:34.332: //28231/EB59E1D3B413/SIP/Info/verbose/1024/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Feb 19 20:19:34.332: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x2760FB28) counter, current msg->refCount = 1
Feb 19 20:19:34.332: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x2B6A0A10) with key=[23215] to table
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/notify/262144/ccsipRegisterSetTargetInfo: p2p mode with Registrar Server = dns:bumblebee.vtnoc.net
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/verbose/262144/ccsipRegisterSetTargetInfo: Parsing The Registrar Address
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/verbose/5120/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : bumblebee.vtnoc.net target_port : 5060
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/verbose/5120/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/critical/8192/sipSPIOutboundProxyReuse: Do not reuse Outbound Proxy IP adress and Port
Feb 19 20:19:35.886: //-1/000000000000/SIP/State/sipSPIChangeState: 0x2B6A0A10 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/verbose/6144/ccsip_spi_registrar_add_expires_header: Inside ccsip_spi_registrar_add_expires_header for Expires
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIIncrementOverloadCount: Local 1 Global 1
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x2B6C6D50) with key=[23216] to table
Feb 19 20:19:35.886: //-1/000000000000/SIP/State/sipSPIChangeState: 0x2B6C6D50 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIIncrementOverloadCount: Local 1 Global 2
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x2B6AD5D0) with key=[23217] to table
Feb 19 20:19:35.886: //-1/000000000000/SIP/State/sipSPIChangeState: 0x2B6AD5D0 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIIncrementOverloadCount: Local 1 Global 3
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 40
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/verbose/262144/act_idle_outgoing_register: In act_idle_outgoing_register
Feb 19 20:19:35.886: //28232/000000000000/SIP/Info/info/262144/act_idle_outgoing_register: Send REGISTER to bumblebee.vtnoc.net:5060
Feb 19 20:19:35.886: //28232/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToUACTable: ****Adding to UAC table.0x2B6A0A10 4DC50FFD-D67211E5-B373DD4E-41EF9C4A
Feb 19 20:19:35.886: //28232/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x2B6A0A10 key=4DC50FFD-D67211E5-B373DD4E-41EF9C4A balance 0
Feb 19 20:19:35.886: //28232/000000000000/SIP/Info/info/262144/act_idle_outgoing_register: Locally Resolved IP:66.147.235.3:5060
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/ccsip_get_ifaddress: ip_address IPv4 12.1.2.3 for SIP
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 12.1.2.3 for SIP
Feb 19 20:19:35.886: //28232/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: signaling bind address : 12.1.2.3
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 12.1.2.3
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x27321740 with refCount = 1
Feb 19 20:19:35.886: //28232/000000000000/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 7 event
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIRetrieveOutgoingPassThruData: Retrieving Data from RCB
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
Feb 19 20:19:35.886: //28232/000000000000/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:35.886: //28232/000000000000/SIP/Info/info/4096/sipSPISendRegister: Associated container=0x2F939688 to Register
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:19:35.886: //28232/000000000000/SIP/Transport/sipSPISendRegister: Sending REGISTER to the transport layer
Feb 19 20:19:35.886: //28232/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:35.886: //28232/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x27321740, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x4F4EA94
Feb 19 20:19:35.886: //28232/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x2B6A0A10 with connection=0x24D9EACC context list
Feb 19 20:19:35.886: //28232/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x27321740
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x27321740, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:35.886: //28232/000000000000/SIP/State/sipSPIChangeState: 0x2B6A0A10 : State change from (STATE_IDLE, SUBSTATE_NONE) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
Feb 19 20:19:35.886: //28232/000000000000/SIP/State/sipSPIChangeState: 0x2B6A0A10 : State change from (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/info/262144/act_idle_outgoing_register: Send REGISTER to bumblebee.vtnoc.net:5060
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToUACTable: ****Adding to UAC table.0x2B6C6D50 4DC50FFD-D67211E5-B377DD4E-41EF9C4A
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x2B6C6D50 key=4DC50FFD-D67211E5-B377DD4E-41EF9C4A balance 1
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/info/262144/act_idle_outgoing_register: Locally Resolved IP:66.147.235.3:5060
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: signaling bind address : 12.1.2.3
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2118DDB0 with refCount = 1
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 7 event
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/info/4096/sipSPISendRegister: Associated container=0x2F938558 to Register
Feb 19 20:19:35.886: //-1/000000000000/SIP/Transport/sipSPISendRegister: Sending REGISTER to the transport layer
Feb 19 20:19:35.886: //-1/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:35.886: //-1/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x2118DDB0, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x4F4EA94
Feb 19 20:19:35.886: //-1/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x2B6C6D50 with connection=0x24D9EACC context list
Feb 19 20:19:35.886: //-1/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2118DDB0
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2118DDB0, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:35.886: //-1/000000000000/SIP/State/sipSPIChangeState: 0x2B6C6D50 : State change from (STATE_IDLE, SUBSTATE_NONE) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
Feb 19 20:19:35.886: //-1/000000000000/SIP/State/sipSPIChangeState: 0x2B6C6D50 : State change from (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToUACTable: ****Adding to UAC table.0x2B6AD5D0 4DC50FFD-D67211E5-B379DD4E-41EF9C4A
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x2B6AD5D0 key=4DC50FFD-D67211E5-B379DD4E-41EF9C4A balance 0
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x24CCC698 with refCount = 1
Feb 19 20:19:35.886: //-1/000000000000/SIP/Info/info/4096/sipSPISendRegister: Associated container=0x2F938818 to Register
Feb 19 20:19:35.886: //-1/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x24CCC698, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x4F4EA94
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x2B6AD5D0 with connection=0x24D9EACC context list
Feb 19 20:19:35.886: //-1/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x24CCC698
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x24CCC698, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:35.886: //-1/000000000000/SIP/State/sipSPIChangeState: 0x2B6AD5D0 : State change from (STATE_IDLE, SUBSTATE_NONE) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
Feb 19 20:19:35.886: //-1/000000000000/SIP/State/sipSPIChangeState: 0x2B6AD5D0 : State change from (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:bumblebee.vtnoc.net:5060 SIP/2.0
Via: SIP/2.0/UDP 12.1.2.3:5060;branch=z9hG4bK798E110F
From: <sip:2001@bumblebee.vtnoc.net>;tag=B8F1AC9C-1898
To: <sip:2001@bumblebee.vtnoc.net>
Date: Fri, 19 Feb 2016 20:19:35 GMT
Call-ID: 4DC50FFD-D67211E5-B373DD4E-41EF9C4A
Max-Forwards: 70
Timestamp: 1455913175
CSeq: 40 REGISTER
Contact: <sip:2001@12.1.2.3:5060>
Expires: 300
Supported: path
Content-Length: 0
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x27321740
Sent:
Via: SIP/2.0/UDP 12.1.2.3:5060;branch=z9hG4bK798F111F
From: <sip:2005@bumblebee.vtnoc.net>;tag=B8F1AC9C-67
To: <sip:2005@bumblebee.vtnoc.net>
Call-ID: 4DC50FFD-D67211E5-B377DD4E-41EF9C4A
Max-Forwards: 70
CSeq: 40 REGISTER
Contact: <sip:2005@12.1.2.3:5060>
Expires: 300
Supported: path
Content-Length: 0
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2118DDB0
Sent:
Via: SIP/2.0/UDP 12.1.2.3:5060;branch=z9hG4bK799072
From: <sip:2009@bumblebee.vtnoc.net>;tag=B8F1AC9C-F9C
To: <sip:2009@bumblebee.vtnoc.net>
Call-ID: 4DC50FFD-D67211E5-B379DD4E-41EF9C4A
Max-Forwards: 70
CSeq: 40 REGISTER
Contact: <sip:2009@12.1.2.3:5060>
Expires: 300
Supported: path
Content-Length: 0
Feb 19 20:19:35.886: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x24CCC698
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x2B69A430) with key=[23218] to table
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/notify/262144/ccsipRegisterSetTargetInfo: p2p mode with Registrar Server = dns:bumblebee.vtnoc.net
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/verbose/262144/ccsipRegisterSetTargetInfo: Parsing The Registrar Address
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/verbose/5120/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : bumblebee.vtnoc.net target_port : 5060
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/verbose/5120/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/critical/8192/sipSPIOutboundProxyReuse: Do not reuse Outbound Proxy IP adress and Port
Feb 19 20:19:35.890: //-1/000000000000/SIP/State/sipSPIChangeState: 0x2B69A430 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/verbose/6144/ccsip_spi_registrar_add_expires_header: Inside ccsip_spi_registrar_add_expires_header for Expires
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIIncrementOverloadCount: Local 1 Global 4
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x2B6B3BB0) with key=[23219] to table
Feb 19 20:19:35.890: //-1/000000000000/SIP/State/sipSPIChangeState: 0x2B6B3BB0 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIIncrementOverloadCount: Local 1 Global 5
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 40
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/verbose/262144/act_idle_outgoing_register: In act_idle_outgoing_register
Feb 19 20:19:35.890: //28235/000000000000/SIP/Info/info/262144/act_idle_outgoing_register: Send REGISTER to bumblebee.vtnoc.net:5060
Feb 19 20:19:35.890: //28235/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToUACTable: ****Adding to UAC table.0x2B69A430 4DC50FFD-D67211E5-B374DD4E-41EF9C4A
Feb 19 20:19:35.890: //28235/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x2B69A430 key=4DC50FFD-D67211E5-B374DD4E-41EF9C4A balance 0
Feb 19 20:19:35.890: //28235/000000000000/SIP/Info/info/262144/act_idle_outgoing_register: Locally Resolved IP:66.147.235.3:5060
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/ccsip_get_ifaddress: ip_address IPv4 12.1.2.3 for SIP
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 12.1.2.3 for SIP
Feb 19 20:19:35.890: //28235/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: signaling bind address : 12.1.2.3
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 12.1.2.3
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x232E2520 with refCount = 1
Feb 19 20:19:35.890: //28235/000000000000/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 7 event
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIRetrieveOutgoingPassThruData: Retrieving Data from RCB
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
Feb 19 20:19:35.890: //28235/000000000000/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:35.890: //28235/000000000000/SIP/Info/info/4096/sipSPISendRegister: Associated container=0x2F9399A0 to Register
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:19:35.890: //28235/000000000000/SIP/Transport/sipSPISendRegister: Sending REGISTER to the transport layer
Feb 19 20:19:35.890: //28235/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:35.890: //28235/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x232E2520, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x4F4EA94
Feb 19 20:19:35.890: //28235/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x2B69A430 with connection=0x24D9EACC context list
Feb 19 20:19:35.890: //28235/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x232E2520
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x232E2520, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:35.890: //28235/000000000000/SIP/State/sipSPIChangeState: 0x2B69A430 : State change from (STATE_IDLE, SUBSTATE_NONE) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
Feb 19 20:19:35.890: //28235/000000000000/SIP/State/sipSPIChangeState: 0x2B69A430 : State change from (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/info/262144/act_idle_outgoing_register: Send REGISTER to bumblebee.vtnoc.net:5060
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToUACTable: ****Adding to UAC table.0x2B6B3BB0 4DC50FFD-D67211E5-B378DD4E-41EF9C4A
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x2B6B3BB0 key=4DC50FFD-D67211E5-B378DD4E-41EF9C4A balance 1
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/info/262144/act_idle_outgoing_register: Locally Resolved IP:66.147.235.3:5060
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: signaling bind address : 12.1.2.3
Feb 19 20:19:35.890: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2118DDB0 with refCount = 1
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 7 event
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:35.890: //-1/000000000000/SIP/Info/info/4096/sipSPISendRegister: Associated container=0x2F937ED0 to Register
Feb 19 20:19:35.890: //-1/000000000000/SIP/Transport/sipSPISendRegister: Sending REGISTER to the transport layer
Feb 19 20:19:35.890: //-1/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE,uri="sip:bumblebee.vtnoc.net:5060",response="1faa69f467f50792d76a833078f10fa4",nonce="56c778f600003b0f017bc5bccb960caee1df4808c51e78e6",cnonce="82E89FBA",qop=auth,algorithm=md5,nc=00000001
Content-Length: 0
Feb 19 20:19:35.962: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x232E2520
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x232E2520 with refCount = 1
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x204E3B74 with refCount = 1
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [66.147.235.3]:5060, local_address:[12.1.2.3]
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x232E2520
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2498648C
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connid=4, transport=UDP
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5060 connId 4
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_get_method_from_request:
Unable to extract request line from message
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 19 20:19:36.022: //-1/000000000000/SIP/Info/info/1024/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK799710E5 from via branch list
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x204E3B74) counter, current msg->refCount = 2
Feb 19 20:19:36.022: //-1/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 12.1.2.3:5060;received=12.1.2.3;rport=62497;branch=z9hG4bK799710E5
To: <sip:2005@bumblebee.vtnoc.net>;tag=8324aa8d99b6bc7e21f3eb535a640969.1014
CSeq: 41 REGISTER
Contact: <sip:2005@12.1.2.3:5060>;expires=300;received="sip:12.1.2.3:62497"
Server: OpenSIPS (1.8.3-tls (x86_64/linux))
Content-Length: 0
Warning: 392 66.147.235.3:5060 "Noisy feedback tells: pid=31738 req_src_ip=12.1.2.3 req_src_port=62497 in_uri=sip:bumblebee.vtnoc.net:5060 out_uri=sip:bumblebee.vtnoc.net:5060 via_cnt==1"
Feb 19 20:19:36.022: //-1/000000000000/SIP/Info/verbose/1024/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIDecrementOverloadCount: Count:Local 0 Global 6
Feb 19 20:19:36.022: //-1/000000000000/SIP/Info/notify/262144/sipSPIRegPthruProcessResponse: Processing response w/ resp code == 200
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/verbose/262144/sipSPIGetRPCBFromRCB: Retreiving RCB [0x2B825288] from RPCB [0x0]
Feb 19 20:19:36.022: //-1/000000000000/SIP/Info/critical/262144/sipSPIRegPthruProcessResponse: Error NO RPCB
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/ccsipRegisterStartRCBTimer: Starting timer for pattern 2005 for 240 seconds
Feb 19 20:19:36.022: //-1/000000000000/SIP/Info/notify/1024/ccsip_gw_register_process_response: No P-Assoicated-URI present in Register Response
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x204E3B74) counter, current msg->refCount = 1
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[23216] removed.
Feb 19 20:19:36.022: //-1/000000000000/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x2B6C6D50 key=4DC50FFD-D67211E5-B377DD4E-41EF9C4A
Feb 19 20:19:36.022: //-1/000000000000/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, unregistering context=0x2B6C6D50
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstancePurgeContextInConnection: Purging context gcb=0x2B6C6D50 from the connection=0x24D9EACC context list
Feb 19 20:19:36.022: //-1/000000000000/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Feb 19 20:19:36.022: //-1/000000000000/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
Feb 19 20:19:36.022: //28233/000000000000/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x2B6C6D50
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[23216]
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x204E3B74
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:19:36.022: //28232/000000000000/SIP/Info/info/1024/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK799521ED from via branch list
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x232E2520) counter, current msg->refCount = 2
Feb 19 20:19:36.022: //28232/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 12.1.2.3:5060;received=12.1.2.3;rport=62497;branch=z9hG4bK799521ED
To: <sip:2001@bumblebee.vtnoc.net>;tag=8324aa8d99b6bc7e21f3eb535a640969.69a4
CSeq: 41 REGISTER
Contact: <sip:2001@12.1.2.3:5060>;expires=300;received="sip:12.1.2.3:62497"
Content-Length: 0
Warning: 392 66.147.235.3:5060 "Noisy feedback tells: pid=31748 req_src_ip=12.1.2.3 req_src_port=62497 in_uri=sip:bumblebee.vtnoc.net:5060 out_uri=sip:bumblebee.vtnoc.net:5060 via_cnt==1"
Feb 19 20:19:36.022: //28232/000000000000/SIP/Info/verbose/1024/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIDecrementOverloadCount: Count:Local 0 Global 5
Feb 19 20:19:36.022: //28232/000000000000/SIP/Info/notify/262144/sipSPIRegPthruProcessResponse: Processing response w/ resp code == 200
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/verbose/262144/sipSPIGetRPCBFromRCB: Retreiving RCB [0x2B8235C0] from RPCB [0x0]
Feb 19 20:19:36.022: //28232/000000000000/SIP/Info/critical/262144/sipSPIRegPthruProcessResponse: Error NO RPCB
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/ccsipRegisterStartRCBTimer: Starting timer for pattern 2001 for 240 seconds
Feb 19 20:19:36.022: //28232/000000000000/SIP/Info/notify/1024/ccsip_gw_register_process_response: No P-Assoicated-URI present in Register Response
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x232E2520) counter, current msg->refCount = 1
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[23215] removed.
Feb 19 20:19:36.022: //28232/000000000000/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x2B6A0A10 key=4DC50FFD-D67211E5-B373DD4E-41EF9C4A
Feb 19 20:19:36.022: //28232/000000000000/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, unregistering context=0x2B6A0A10
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstancePurgeContextInConnection: Purging context gcb=0x2B6A0A10 from the connection=0x24D9EACC context list
Feb 19 20:19:36.022: //28232/000000000000/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Feb 19 20:19:36.022: //28232/000000000000/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
Feb 19 20:19:36.022: //28232/000000000000/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x2B6A0A10
Feb 19 20:19:36.022: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[23215]
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [66.147.235.3]:5060, local_address:[12.1.2.3]
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2498648C
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connid=4, transport=UDP
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5060 connId 4
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_get_method_from_request:
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 19 20:19:36.026: //28235/000000000000/SIP/Info/info/1024/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK79981D51 from via branch list
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x245391FC) counter, current msg->refCount = 2
Feb 19 20:19:36.026: //28235/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 12.1.2.3:5060;received=12.1.2.3;rport=62497;branch=z9hG4bK79981D51
From: <sip:2002@bumblebee.vtnoc.net>;tag=B8F1ACA0-30F
To: <sip:2002@bumblebee.vtnoc.net>;tag=8324aa8d99b6bc7e21f3eb535a640969.4ae7
Call-ID: 4DC50FFD-D67211E5-B374DD4E-41EF9C4A
CSeq: 41 REGISTER
Contact: <sip:2002@12.1.2.3:5060>;expires=300;received="sip:12.1.2.3:62497"
Content-Length: 0
Warning: 392 66.147.235.3:5060 "Noisy feedback tells: pid=31758 req_src_ip=12.1.2.3 req_src_port=62497 in_uri=sip:bumblebee.vtnoc.net:5060 out_uri=sip:bumblebee.vtnoc.net:5060 via_cnt==1"
Feb 19 20:19:36.026: //28235/000000000000/SIP/Info/verbose/1024/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIDecrementOverloadCount: Count:Local 0 Global 4
Feb 19 20:19:36.026: //28235/000000000000/SIP/Info/notify/262144/sipSPIRegPthruProcessResponse: Processing response w/ resp code == 200
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/verbose/262144/sipSPIGetRPCBFromRCB: Retreiving RCB [0x276181E0] from RPCB [0x0]
Feb 19 20:19:36.026: //28235/000000000000/SIP/Info/critical/262144/sipSPIRegPthruProcessResponse: Error NO RPCB
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/ccsipRegisterStartRCBTimer: Starting timer for pattern 2002 for 240 seconds
Feb 19 20:19:36.026: //28235/000000000000/SIP/Info/notify/1024/ccsip_gw_register_process_response: No P-Assoicated-URI present in Register Response
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x245391FC) counter, current msg->refCount = 1
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[23218] removed.
Feb 19 20:19:36.026: //28235/000000000000/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x2B69A430 key=4DC50FFD-D67211E5-B374DD4E-41EF9C4A
Feb 19 20:19:36.026: //28235/000000000000/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, unregistering context=0x2B69A430
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstancePurgeContextInConnection: Purging context gcb=0x2B69A430 from the connection=0x24D9EACC context list
Feb 19 20:19:36.026: //28235/000000000000/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Feb 19 20:19:36.026: //28235/000000000000/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
Feb 19 20:19:36.026: //28235/000000000000/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x2B69A430
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[23218]
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:19:36.026: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x24CCC698 with refCount = 1
Feb 19 20:19:36.028: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2FC5EE44
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2FC5EE44 with refCount = 1
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2118DDB0 with refCount = 1
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [66.147.235.3]:5060, local_address:[12.1.2.3]
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2FC5EE44
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2498648C
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connid=4, transport=UDP
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5060 connId 4
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_get_method_from_request:
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x2118DDB0) counter, current msg->refCount = 2
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 12.1.2.3:5060;rport=62497;received=12.1.2.3;branch=z9hG4bK798DDA8
To: <sip:+18662966457@bumblebee.vtnoc.net>;tag=gK04fa5845
CSeq: 102 INVITE
Record-Route: <sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Record-Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>
Contact: <sip:+18662966457@4.55.23.33:5060>
Allow: INVITE,ACK,CANCEL,BYE,PRACK,UPDATE
Require: 100rel
RSeq: 22423
Content-Length: 231
Content-Disposition: session; handling=required
Content-Type: application/sdp
v=0
o=Sonus_UAC 16186 28782 IN IP4 4.55.23.33
s=SIP Media Capabilities
c=IN IP4 4.55.23.6
t=0 0
m=audio 19896 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/1024/sipSPICheckResponseExt: Got new RR header
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/1024/sipSPICheckResponseExt: This is first RR in this dialog
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/critical/4096/sipSPICheckReliableProvStringtag: Unable to access supported header values
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentGTD: No GTD found in inbound container
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/1/sipSPIDoMediaNegotiation: Number of m-lines = 1
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/1/sipSPIValidateConnectionAddress: Dest port = 19896
SIP: Attribute mid, level 1 instance 1 not found.
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 12.1.2.3
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved as its in use by other codec
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPIUpdateDynamicPT: Requested payload-Type (101) is reserved by another application
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/1/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/1/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/8/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/1/sipSPIDoDTMFRelayNegotiation: m-line index 1
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/1/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/32/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/1/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/8209/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/critical/8193/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/1/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/1/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
stream_type=voice+dtmf (1), dest_ip_address=4.55.23.6, dest_port=19896
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/sipSPIChangeStreamState: Stream (callid = -1) State changed from (STREAM_DEAD) to (STREAM_ADDING)
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/131073/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/131072/sipSPIDoStreamQoSNegotiation: Best effort
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_iwf_handle_generic_event:
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP, event:E_SIP_IWF_EV_CALL_BRIDGE
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_iwf_process_event: IWF - cnfsm ret 2
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec : g711ulaw, bytes :160
Preferred DTMF relay : rtp-nte
Preferred NTE payload : 101
Early Media : No
Delayed Media : No
Bridge Done : No
New Media : No
DSP DNLD Reqd : No
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_offer_ans_handle_rcvd_sdp:
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_OFFER_SENT, event:E_SIP_INVITE_RESP_SDP_RCVD
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_offer_ans_is_incoming_invite_resp_answer_valid: TRUE
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_offer_ans_common_answer_rcvd_hdlr:
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_iwf_handle_network_event:
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP, event:E_SIP_IWF_EV_RCVD_SDP
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/sip_iwf_def_ed_rcvd_sdp_answer_hdlr:
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/131074/sipSPIBwCacCalcNegoAudioBandwidth: max audio bw (including pak overhead) from negotiated stream : codec g711ulaw bw 80000 bps index 1
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacUpdateAccountedBw: bwcac update accounted BW Option 1 flow mode flow-through
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacUpdateInterfaceBw: bwcac updating interface BVI255 bw 80
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacUpdateAccountedBw: bwcac update accounted bw (initial answer) accounted bw adjusted to 80000 delta 80000
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_DONE
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_ANSWER_COMPLETE
Stream type : voice+dtmf
Media line : 1
State : STREAM_ADDING (2)
Stream address type : 1
Callid : 28231
Negotiated Codec : g711ulaw, bytes :160
Nego. Codec payload : 0 (tx), 0 (rx)
Negotiated DTMF relay : rtp-nte
Negotiated NTE payload : 101 (tx), 101 (rx)
Negotiated CN payload : 0
Media Srce Addr/Port : [12.1.2.3]:19606
Media Dest Addr/Port : [4.55.23.6]:19896
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/critical/1024/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/133120/sipSPIBwCacIsDialPeerBwAvailable: bwcac NOP dial-peer bw available tag 13
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/1/sipSPIBwCacIsInterfaceBwAvailable: bwcac interface bw threshold not configured
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacVerifyBwThreshold: bwcac verify bw threshold, bw available allow call total bw 80000 bps
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/critical/12288/sipSPICreateNewRawMsg: No Data to form The Raw Message
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/HandleSIP1xxSessionProgress: ccsip_api_call_cut_progress returned: SIP_SUCCESS
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/sipSPIChangeState: 0x2B6BA190 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING) to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 2 event
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPIAddRouteHeaders: status = TRUE Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>,<sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4096/sipSPIGenerateAuthorizationResponse: HA1 is: 3c7356a2d9242d5bcca92572790352ff
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendPrack: Associated container=0x2F937C68 to Prack
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x245391FC, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x4F4F9F8
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x245391FC
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x245391FC, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/512/sentPrack: Sent Prack Request, starting PrackTimer
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/sipSPIChangeState: 0x2B6BA190 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING) to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4096/HandleSIP1xxSessionProgress: Transaction active. Facilities will be queued.
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x2118DDB0) counter, current msg->refCount = 1
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_bridge: confID = 1104, srcCallID = 28231, dstCallID = 28230
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/1/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 28231/28230
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/1/sipSPIUupdateCcCallIds: Old streamcallid=28231, new streamcallid=28231
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_CALL_BRIDGE
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/256/ccsip_bridge: xcoder_attached = 0, xmitFunc = 0x4848172, ccb xmitFunc = 0x4848172
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/24576/ccsip_spi_check_call_locally_held: CCSIP: call is locally noton-hold
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/6/sipSPIAddStream: set stream_callid from ccb->ccCallID:0x6E47, media_type:0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 28231) to the VOIP RTP library
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/1/sipSPIAssignStreamCallId: Assigning streamid 28231 to stream 1. Old streamid = 28231
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/8192/sipSPIUpdateRtcpSession: ccb->flags != LOOPBACK
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPIUpdateRtcpSession: setting do_rtcp= TRUE for non forked leg 1
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/1/is_call_held: Remote media IP addr: 4.55.23.6
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/1/is_call_held: Media IP Addr 4.55.23.6, RTCP Type 3
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 12.1.2.3, lport = 19606, raddr = 4.55.23.6, rport=19896, do_rtcp=TRUE
src_callid = 28231, dest_callid = 28230, stream type = voice+dtmf, stream direction = SENDRECV
media_ip_addr = 4.55.23.6, vrf tableid = 0 media_addr_type = 1negotiated_bandwidth (kbps) = 0 srtp_services = 0 nat_flag = 0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:2FA7142C
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/critical/131072/sipSPIUpdateRtcpSession: Not able to Associate DSCP Profile with GCCB dscp_policy = 0x0, IS_SIPSPI_MODE_IN_SIP_SIP = 0 dscpPolicySeviceBlock = 0x0 , stream->qos_info = 0x0
Feb 19 20:19:40.335: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=28231
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/8193/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/2080/sipSPIUpdateRtcpSession: DTMF inb/oob iwf enabled 0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4097/sipSPI_ipip_is_escalation: local channels = 0, peer channels = 0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPIGetNewLocalMediaDirection:
New Remote Media Direction = SENDRECV
Present Local Media Direction = SENDRECV
New Local Media Direction = SENDRECV
retVal = 0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/sipSPIChangeStreamState: Stream (callid = 28231) State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/notify/32/ccsip_bridge:
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_run_deferred_media_negotiate:
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_is_media_negotiate_app_trigger_reinvite_deferred: retVal : 0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: CC_EV_CALL_PING_DONE
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: IWF Event: E_SIP_IWF_EV_PEER_CAPS
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_PEER_CAPS
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/is_mode_sip_sccp_do_video:
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/sip_iwf_def_peer_caps_ind_hdlr:
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4097/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=28231, current_seq_num=0x1ABD
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4097/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=28231, current_seq_num=0xD93
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/1/sip_iwf_def_process_caps_ind: Load DSP with negotiated codec: g711ulaw, Bytes=160
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/1/sip_iwf_def_process_caps_ind: Set forking flag to 0x0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/32/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/10241/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/12288/sipSPIGetModemInfoPerCall: peer_callID=28230
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/8193/sip_set_modem_caps: Disabling Modem Relay...
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/8193/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/8193/sip_set_modem_caps: Modem Relay & Passthru both disabled
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/8193/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
line 1 codec g711ulaw
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Media/sipSPISetStreamInfo: 0x2FB73330 (gccb)
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/1/sip_iwf_def_process_caps_ind: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/1/sip_iwf_def_process_caps_ind: ccsip_caps_ind: ccb->pld.flags_ipip = 0x2201
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/1/sip_iwf_def_process_caps_ind: Calling cc_api_caps_ack()
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 7
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IPIPMS:cur_container:ccsip_ipip_media_service_main_container, cur_state:S_IPIP_MEDIA_SERV_STATE_IDLE, event:E_IPIP_MEDIA_SERV_EV_PEER_CAPS_IND
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_iwf_handle_peer_event: Return value: SIP_IWF_SUCCESS
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_iwf_map_cc_return_code: Mapping SIP_IWF_SUCCESS
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: CC_EV_CALL_FEATURE
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: IWF Event: E_SIP_IWF_EV_PEER_CAPS_ACK,
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_PEER_CAPS_ACK,
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/is_mode_sip_sccp:
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/info/4096/sip_iwf_def_peer_caps_ack_hdlr:
Feb 19 20:19:40.335: //28231/EB59E1D3B413/SIP/Info/verbose/8193/sip_iwf_tdm_process_caps_ack: Set forking flag to 0x0
Feb 19 20:19:40.337: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:+18662966457@4.55.23.33:5060 SIP/2.0
Via: SIP/2.0/UDP 12.1.2.3:5060;branch=z9hG4bK799C19D1
To: <sip:18662966457@bumblebee.vtnoc.net>;tag=gK04fa5845
CSeq: 103 PRACK
RAck: 22423 102 INVITE
Allow-Events: telephone-event
Proxy-Authorization: Digest username="17866462052",realm="bumblebee.vtnoc.net",uri="sip:+18662966457@4.55.23.33:5060",response="a64cb0c01ee0b2356de4f2cb186dbbda",nonce="56c778f400003ade2d1a1a773ec81adab2a27b7968305c47",cnonce="EE93A286",qop=auth,algorithm=md5,nc=00000002
Max-Forwards: 70
Content-Length: 0
Feb 19 20:19:40.337: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [66.147.235.3]:5060, local_address:[12.1.2.3]
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2498648C
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connid=4, transport=UDP
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5060 connId 4
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_get_method_from_request:
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x2760FB28) counter, current msg->refCount = 2
Feb 19 20:19:40.826: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Require: 100rel
RSeq: 22423
Content-Length: 231
v=0
c=IN IP4 4.55.23.6
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Feb 19 20:19:40.826: //28231/EB59E1D3B413/SIP/Info/verbose/1024/sipSPICheckResponseExt: Got new RR header
Feb 19 20:19:40.826: //28231/EB59E1D3B413/SIP/Info/notify/1024/HandleSIP1xxSessionProgress: Dropping 183 - Duplicate or Unexpected
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x2760FB28) counter, current msg->refCount = 1
Feb 19 20:19:40.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:19:40.836: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:19:40.836: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPIAddRouteHeaders: status = TRUE Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>,<sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Feb 19 20:19:40.836: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendPrack: Associated container=0x2F937C68 to Prack
Feb 19 20:19:40.836: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:19:40.836: //28231/EB59E1D3B413/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
Feb 19 20:19:40.836: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:40.836: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x2760FB28, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x0
Feb 19 20:19:40.836: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:40.836: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:40.836: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:19:40.836: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:19:40.836: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2760FB28
Feb 19 20:19:40.836: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2760FB28, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:40.836: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
From: "DJ's Test phone" <sip:200@bumblebee.vtnoc.net>;tag=B8F1A5F4-1DF9
Date: Fri, 19 Feb 2016 20:19:34 GMT
Call-ID: ECC8824B-D67C11E5-B418DD4E-41EF9C4A@12.1.2.3
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
Feb 19 20:19:40.836: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [66.147.235.3]:5060, local_address:[12.1.2.3]
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2498648C
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connid=4, transport=UDP
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5060 connId 4
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_get_method_from_request:
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x245391FC) counter, current msg->refCount = 2
Feb 19 20:19:41.826: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Require: 100rel
RSeq: 22423
Content-Length: 231
v=0
c=IN IP4 4.55.23.6
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Feb 19 20:19:41.826: //28231/EB59E1D3B413/SIP/Info/verbose/1024/sipSPICheckResponseExt: Got new RR header
Feb 19 20:19:41.826: //28231/EB59E1D3B413/SIP/Info/notify/1024/HandleSIP1xxSessionProgress: Dropping 183 - Duplicate or Unexpected
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x245391FC) counter, current msg->refCount = 1
Feb 19 20:19:41.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:19:41.836: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:41.836: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPIAddRouteHeaders: status = TRUE Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>,<sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Feb 19 20:19:41.836: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendPrack: Associated container=0x2F937C68 to Prack
Feb 19 20:19:41.836: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:19:41.836: //28231/EB59E1D3B413/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
Feb 19 20:19:41.836: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:41.836: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x245391FC, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x0
Feb 19 20:19:41.836: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:41.836: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:41.836: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:19:41.836: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:19:41.836: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x245391FC
Feb 19 20:19:41.836: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x245391FC, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:41.836: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
Feb 19 20:19:41.836: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:19:43.506: //28231/EB59E1D3B413/SIP/Info/verbose/32768/ccsip_indicate_rt_packet_stats: Processing stats for callid=28231, proc_id=9
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [66.147.235.3]:5060, local_address:[12.1.2.3]
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2498648C
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connid=4, transport=UDP
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5060 connId 4
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_get_method_from_request:
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x2760FB28) counter, current msg->refCount = 2
Feb 19 20:19:43.826: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Require: 100rel
RSeq: 22423
Content-Length: 231
v=0
c=IN IP4 4.55.23.6
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Feb 19 20:19:43.826: //28231/EB59E1D3B413/SIP/Info/verbose/1024/sipSPICheckResponseExt: Got new RR header
Feb 19 20:19:43.826: //28231/EB59E1D3B413/SIP/Info/notify/1024/HandleSIP1xxSessionProgress: Dropping 183 - Duplicate or Unexpected
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x2760FB28) counter, current msg->refCount = 1
Feb 19 20:19:43.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:19:43.836: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:19:43.836: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPIAddRouteHeaders: status = TRUE Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>,<sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Feb 19 20:19:43.836: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendPrack: Associated container=0x2F937C68 to Prack
Feb 19 20:19:43.836: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:19:43.836: //28231/EB59E1D3B413/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
Feb 19 20:19:43.836: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:43.836: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x2760FB28, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x0
Feb 19 20:19:43.836: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:43.836: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:43.836: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:19:43.836: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:19:43.836: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2760FB28
Feb 19 20:19:43.836: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2760FB28, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:43.836: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
Feb 19 20:19:43.836: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:19:45.879: //28231/EB59E1D3B413/SIP/Info/verbose/32768/ccsip_indicate_rt_packet_stats: Processing stats for callid=28231, proc_id=9
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [66.147.235.3]:5060, local_address:[12.1.2.3]
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2498648C
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connid=4, transport=UDP
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5060 connId 4
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_get_method_from_request:
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x245391FC) counter, current msg->refCount = 2
Feb 19 20:19:47.826: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Require: 100rel
RSeq: 22423
Content-Length: 231
v=0
c=IN IP4 4.55.23.6
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Feb 19 20:19:47.826: //28231/EB59E1D3B413/SIP/Info/verbose/1024/sipSPICheckResponseExt: Got new RR header
Feb 19 20:19:47.826: //28231/EB59E1D3B413/SIP/Info/notify/1024/HandleSIP1xxSessionProgress: Dropping 183 - Duplicate or Unexpected
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x245391FC) counter, current msg->refCount = 1
Feb 19 20:19:47.826: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:19:47.838: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:47.838: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPIAddRouteHeaders: status = TRUE Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>,<sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Feb 19 20:19:47.838: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendPrack: Associated container=0x2F937C68 to Prack
Feb 19 20:19:47.838: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:19:47.838: //28231/EB59E1D3B413/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
Feb 19 20:19:47.838: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:47.838: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x245391FC, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x0
Feb 19 20:19:47.838: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:47.838: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:47.838: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:19:47.838: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:19:47.838: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x245391FC
Feb 19 20:19:47.838: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x245391FC, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:47.838: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
Feb 19 20:19:47.838: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:19:51.839: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:51.839: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPIAddRouteHeaders: status = TRUE Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>,<sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Feb 19 20:19:51.839: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendPrack: Associated container=0x2F937C68 to Prack
Feb 19 20:19:51.839: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:19:51.839: //28231/EB59E1D3B413/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
Feb 19 20:19:51.839: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:51.839: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x245391FC, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x0
Feb 19 20:19:51.839: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:51.839: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:51.839: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:19:51.839: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:19:51.839: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x245391FC
Feb 19 20:19:51.839: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x245391FC, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:51.839: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
Feb 19 20:19:51.839: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:19:52.083: //28231/EB59E1D3B413/SIP/Info/verbose/32768/ccsip_indicate_rt_packet_stats: Processing stats for callid=28231, proc_id=9
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [66.147.235.3]:5060, local_address:[12.1.2.3]
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2498648C
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connid=4, transport=UDP
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5060 connId 4
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_get_method_from_request:
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x2760FB28) counter, current msg->refCount = 2
Feb 19 20:19:55.616: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Require: 100rel
RSeq: 22423
Content-Length: 231
v=0
c=IN IP4 4.55.23.6
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Feb 19 20:19:55.616: //28231/EB59E1D3B413/SIP/Info/verbose/1024/sipSPICheckResponseExt: Got new RR header
Feb 19 20:19:55.616: //28231/EB59E1D3B413/SIP/Info/notify/1024/HandleSIP1xxSessionProgress: Dropping 183 - Duplicate or Unexpected
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x2760FB28) counter, current msg->refCount = 1
Feb 19 20:19:55.616: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:19:55.840: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:19:55.840: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPIAddRouteHeaders: status = TRUE Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>,<sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Feb 19 20:19:55.840: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendPrack: Associated container=0x2F937C68 to Prack
Feb 19 20:19:55.840: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:19:55.840: //28231/EB59E1D3B413/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
Feb 19 20:19:55.840: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:55.840: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x2760FB28, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x0
Feb 19 20:19:55.840: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:55.840: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:55.840: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:19:55.840: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:19:55.840: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2760FB28
Feb 19 20:19:55.840: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2760FB28, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:55.840: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
Feb 19 20:19:55.840: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:19:57.835: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sipSPIGetRejectedRequestSyslog: Syslog Timer re-started for silent discard
Feb 19 20:19:57.997: //28231/EB59E1D3B413/SIP/Info/verbose/32768/ccsip_indicate_rt_packet_stats: Processing stats for callid=28231, proc_id=9
Feb 19 20:19:59.841: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:19:59.841: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPIAddRouteHeaders: status = TRUE Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>,<sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Feb 19 20:19:59.841: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendPrack: Associated container=0x2F937C68 to Prack
Feb 19 20:19:59.841: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:19:59.841: //28231/EB59E1D3B413/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
Feb 19 20:19:59.841: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:19:59.841: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x2760FB28, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x0
Feb 19 20:19:59.841: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:19:59.841: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:19:59.841: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:19:59.841: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:19:59.841: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2760FB28
Feb 19 20:19:59.841: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2760FB28, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:19:59.841: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
Feb 19 20:19:59.841: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:20:03.843: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:20:03.843: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPIAddRouteHeaders: status = TRUE Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>,<sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Feb 19 20:20:03.843: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendPrack: Associated container=0x2F937C68 to Prack
Feb 19 20:20:03.843: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:20:03.843: //28231/EB59E1D3B413/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
Feb 19 20:20:03.843: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:20:03.843: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x2760FB28, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x0
Feb 19 20:20:03.843: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:20:03.843: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:20:03.843: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:20:03.843: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:20:03.843: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2760FB28
Feb 19 20:20:03.843: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2760FB28, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:20:03.843: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
Feb 19 20:20:03.843: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:20:04.295: //28231/EB59E1D3B413/SIP/Info/verbose/32768/ccsip_indicate_rt_packet_stats: Processing stats for callid=28231, proc_id=9
Feb 19 20:20:07.844: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x2760FB28 with refCount = 1
Feb 19 20:20:07.844: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPIAddRouteHeaders: status = TRUE Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>,<sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Feb 19 20:20:07.844: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendPrack: Associated container=0x2F937C68 to Prack
Feb 19 20:20:07.844: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:20:07.844: //28231/EB59E1D3B413/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
Feb 19 20:20:07.844: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:20:07.844: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x2760FB28, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x0
Feb 19 20:20:07.844: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:20:07.844: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:20:07.844: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:20:07.844: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:20:07.844: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2760FB28
Feb 19 20:20:07.844: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2760FB28, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:20:07.844: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
Feb 19 20:20:07.844: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2760FB28
Feb 19 20:20:11.231: //28231/EB59E1D3B413/SIP/Info/verbose/32768/ccsip_indicate_rt_packet_stats: Processing stats for callid=28231, proc_id=9
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x245391FC with refCount = 1
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x27321740 with refCount = 1
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [66.147.235.3]:5060, local_address:[12.1.2.3]
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x245391FC
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2498648C
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connid=4, transport=UDP
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5060 connId 4
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_get_method_from_request:
Unable to extract request line from message
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x27321740) counter, current msg->refCount = 2
Feb 19 20:20:11.615: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Require: 100rel
RSeq: 22423
Content-Length: 231
v=0
c=IN IP4 4.55.23.6
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Feb 19 20:20:11.615: //28231/EB59E1D3B413/SIP/Info/verbose/1024/sipSPICheckResponseExt: Got new RR header
Feb 19 20:20:11.615: //28231/EB59E1D3B413/SIP/Info/notify/1024/HandleSIP1xxSessionProgress: Dropping 183 - Duplicate or Unexpected
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x27321740) counter, current msg->refCount = 1
Feb 19 20:20:11.615: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x27321740
Feb 19 20:20:11.845: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x27321740 with refCount = 1
Feb 19 20:20:11.845: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/sipSPIAddRouteHeaders: status = TRUE Route: <sip:66.147.235.3:5060;lr;ftag=B8F1A5F4-1DF9;did=12.14cf1136>,<sip:198.8.62.14:5060;lr;ftag=B8F1A5F4-1DF9>
Feb 19 20:20:11.845: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendPrack: Associated container=0x2F937C68 to Prack
Feb 19 20:20:11.845: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:20:11.845: //28231/EB59E1D3B413/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
Feb 19 20:20:11.845: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:20:11.845: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x27321740, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x0
Feb 19 20:20:11.845: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:20:11.845: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:20:11.845: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:20:11.845: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:20:11.845: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x27321740
Feb 19 20:20:11.845: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x27321740, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:20:11.845: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
Feb 19 20:20:11.845: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x27321740
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x27321740 with refCount = 1
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x276089E0 with refCount = 1
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [66.147.235.3]:5060, local_address:[12.1.2.3]
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x27321740
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2498648C
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2498648C, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connid=4, transport=UDP
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5060 connId 4
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_get_method_from_request:
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x276089E0) counter, current msg->refCount = 2
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 482 Loop Detected
To: <sip:+18662966457@bumblebee.vtnoc.net>;tag=gK048030a2
CSeq: 102 INVITE
Content-Length: 0
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/1024/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentGTD: No GTD found in inbound container
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 1 event
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_offer_ans_handle_call_active:
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_OFFER_ANSWER_COMPLETE, event:E_SIP_DIALOG_ESTD
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_offer_ans_dialog_established_hdlr:
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_iwf_handle_generic_event:
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_CALL_ACTIVE
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/4096/is_mode_sip_sip:
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/4096/is_mode_sip_h323:
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/4096/is_mode_sip_h32x:
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/is_mode_sip_sccp:
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/4096/ccsip_iwf_set_tdm_ip_call_active:
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_sccp_mid_dialog_container
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_MID_DIALOG_IDLE
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISendAck: Associated container=0x2F939630 to Ack
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: msg=0x27321740, addr=66.147.235.3, port=5060, sentBy_port=0, local_addr=12.1.2.3, is_req=1, transport=1, switch=0, callBack=0x0
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:66.147.235.3, rport:5060 with laddr:12.1.2.3
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2B6BA190 is already on connection=0x24D9EACC context_list
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x27321740
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x27321740, addr=66.147.235.3, port=5060, local_addr=12.1.2.3, connId=4 for UDP
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/critical/1024/act_recdproc_new_message_response: Received a 4/5/6xx message with StatusCode: 482
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_set_release_source_for_peer: ownCallId[28231], src[4]
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/critical/4096/sipSPIInitiateDisconnect: Initiate call disconnect(127) for outgoing call
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x2118DDB0
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 29
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/critical/32768/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/State/sipSPIChangeState: 0x2B6BA190 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x276089E0) counter, current msg->refCount = 1
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 18
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IPIPMS:cur_container:ccsip_ipip_media_service_main_container, cur_state:S_IPIP_MEDIA_SERV_STATE_IDLE, event:E_IPIP_MEDIA_SERV_EV_XCODER_RESET_STREAM
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/256/sipSPIResetXcoder: *****CLEANING UP XCODER RESOURCES*****
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/256/sipSPIResetXcoder: Xcoder resource already cleaned up
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/State/ccsip_cnfsm_debugs: IPIPMS:next_state:S_IPIP_MEDIA_SERV_STATE_IDLE
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:2FA7142C
Sent:
ACK sip:18662966457@bumblebee.vtnoc.net:5060 SIP/2.0
Via: SIP/2.0/UDP 12.1.2.3:5060;branch=z9hG4bK798DDA8
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/8192/ccsip_call_statistics: Requesting stats for callid=28231
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/32768/ccsip_indicate_rt_packet_stats: Processing stats for callid=28231, proc_id=1
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Configured SE:1800, Configured Min-SE:1800
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/133120/sipSPIBwCacReleaseDialPeerBw: bwcac dial-peer bw 80 Kbps released for tag 13 active bw 0 Kbps
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacReleaseInterfaceBw: bwcac releasing interface BVI255 bw 80 Kbps
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/131072/sipSPIBwCacReleaseAccountedBw: bwcac released accounted bw 80000 bps
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/4096/act_disconnecting_disconnect: Disconnect now.. no defer BYE..
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/4096/sipSPISetCommonTimer: Started generic timer type 2 for 240000 millisecs
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/8192/sipSPIDeferCallClose: Not split dataplane, bail
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/8192/sipSPIWaitForStatsBforeCallClose: Not split dataplane, bail
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/verbose/4096/sipSPICallCloseAfterFinalStat:
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Info/info/12288/sipSPIIcpifUpdate: CallState: 3 Playout: 29560 DiscTime:310288234 ConnTime 0
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/Media/sipSPIHandleDestroyRtpSession: stream:2FA7142C
Feb 19 20:20:12.133: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x276089E0
Feb 19 20:20:12.133: //28231/EB59E1D3B413/SIP/State/sipSPIChangeState: 0x2B6BA190 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
Feb 19 20:20:12.135: //28231/EB59E1D3B413/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x2B6BA190
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 200
Called Number : 18662966457
Source IP Address (Sig ): 12.1.2.3
Destn SIP Req Addr:Port : 66.147.235.3:5060
Destn SIP Resp Addr:Port : 66.147.235.3:5060
Destination Name : bumblebee.vtnoc.net
Feb 19 20:20:12.135: //28231/EB59E1D3B413/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec Bytes : 160
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101 (tx), 101 (rx)
Source IP Address (Media): 12.1.2.3
Source IP Port (Media): 19606
Destn IP Address (Media): 4.55.23.6
Destn IP Port (Media): 19896
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 127
Disconnect Cause (SIP) : 482
Feb 19 20:20:12.135: //28231/EB59E1D3B413/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id 6E47
Feb 19 20:20:12.135: //28231/EB59E1D3B413/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Return and SIP_TIMER_REMOVE_TRANSACTION timer will free this ccb=0x2B6BA190
I am also getting the same error..
Any findings from you..
