Hi,Do the IP phones 7841/8841/8861 come with patch cord or ethernet cable? How to get details of the complete pack that comes in order
Hi All, we’ve installed FreePBX with Cisco voice gateway (ISR 2901-V) and we’re able to make and accept PSTN calls but when the calls got terminated from pstn callers, the sessions keep active on the freepbx soft phones side. It makes the FXO lines o...
Hello Everyone, I have an issue with a few Cisco IP Phones (7940) model. it says registration rejected. and when I brought them to the HQ, it registered directly without any issue. but the strange this is that, when I connect a 7942 or newer models...
Hi,I have an issue with one phone extension only registered to 3 Cisco Phones (DX80, 8861, 8841). when i call it ring for 1 time then forward the call to Cisco unity, so how can i disable the forwarding call. Appreciate your help Thanks
Currently, our IP Communicator installations point to the IP address of our CUCM but this displays an untrusted cert error. How can I change this to the FQDN?
A single extension does not get red blinking lights on it for the MESSAGE WAITING INDICATOR. When i checked the MWI settings for this extension on CUC and compared it to to other phones i saw the following: 1> The phone was not mapped to either publi...
Hello All,I have recently upgraded 88xx phones' firmware version 12.5 to 12.7, and I am noticing a message when speak on call that ' i am a bit louder on the call ' .may I know if I can remove this message.
Hello I have an IAD2430 with an FXO card on it. Customer has an analog line from the provider. I need to send all inbound calls from the provider to the IPPBX via SIP. I have the following config on the IAD, but when I call the phone number the nu...
Hello How can I upgrade my 7841 firmware to 3pcc level ThanksAndrew
I need to have a hunt group with 5 lines to be able to call out to cell phones. Right now it will bounce perfectly but I need it to follow what that station is currently set as....... If no answer ring: cell number. It will not follow what the exte...
When I try to make a call with Jabber it is like a second line is also opened. One of the lines calls the number, I can hear it faintly in the background, but I mainly hear a dial tone from the 'second line'. When I exit Skype, the problem goes away....
Hi, We have configured Hotline between 2 extensions. Ex: from line number 8355, if they lift the receiver it will ring on another extension in 8356 and similarly from line number 8356, if they lift the receiver it will ring on 8355 as hotline. Hotlin...
is there any way to track video usage on the 8945 phones - say in cdr analysis and reporting.Thanks,Paul.
Hello everyone, I am facing a strange behaviour with a Jabber (for Windows) connected through VPN calling an IP Phone. The RTP flow is passing through some Stormshield FW. For the example, the worstation has 2 IP : one Wifi 192.168.0.2 and one VPN 10...
Is it possible to assign both of these the same extension?
Subject | Author | Posted |
05-16-2025 12:03 AM | ||
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM | ||
05-11-2025 04:59 AM | ||
05-05-2025 11:16 AM |
User | Count |
5 | |
4 | |
2 | |
1 | |
1 |
