CUE 8.6 email notifications are not send
c_marquardt
Please, i need help.... we have cisco unity express 8.6,i need enable emal notifications... i followed the administration GUI, but it seems not work...
In message notifications--->notifications administrations---> enable system wide notifications----> OK
                                   --->Subscriber Notification  Management---->edit owners and add email inbox, adding Enable notification to this device.
In System--------> SMTP settings----> OK, we tested it sending an email on Test SMTP Setting, and it´s OK.
Do you miss anything?.....
I will appreciate all of your help...
Carlos
ronpatel
Level 8
Level 8
Hi Carlos,
Refer below steps and see if it resolves the issue.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_3/cliadmin/ch_msgno.html#wp1066504
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak.... this document is for CUE 2.3.... the command "username username profile vm-notif-profile " is not enable in CUE 8.6.
This is the exit of the command
CUE-XXXX# show voicemail notification owner ext8940 email
Profile:             vm-notif-profile
Device:              Email Inbox
Enabled:             Yes
Preference:          Urgent
Email address:       helpdesk@XXXX.cl
Text:
Attach Message:      Yes
Schedule(active hours):
Sunday:     08:00 to 17:00
Monday:     08:00 to 17:00
Tuesday:    08:00 to 17:00
Wednesday:  08:00 to 17:00
Thursday:   08:00 to 17:00
Friday:     08:00 to 17:00
Saturday:   08:00 to 17:00
Thanks anyway.....
