06-07-2012 11:31 AM - edited 03-16-2019 11:33 AM
Please, i need help.... we have cisco unity express 8.6,i need enable emal notifications... i followed the administration GUI, but it seems not work...
In message notifications--->notifications administrations---> enable system wide notifications----> OK
--->Subscriber Notification Management---->edit owners and add email inbox, adding Enable notification to this device.
In System--------> SMTP settings----> OK, we tested it sending an email on Test SMTP Setting, and it´s OK.
Do you miss anything?.....
I will appreciate all of your help...
Carlos
06-07-2012 09:59 PM
Hi Carlos,
Refer below steps and see if it resolves the issue.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_3/cliadmin/ch_msgno.html#wp1066504
Ronak Patel
Rate helpful posts.
06-08-2012 07:33 AM
Hi Ronak.... this document is for CUE 2.3.... the command "username username profile vm-notif-profile " is not enable in CUE 8.6.
This is the exit of the command
CUE-XXXX# show voicemail notification owner ext8940 email
Profile: vm-notif-profile
Device: Email Inbox
Enabled: Yes
Preference: Urgent
Email address: helpdesk@XXXX.cl
Text:
Attach Message: Yes
Schedule(active hours):
Sunday: 08:00 to 17:00
Monday: 08:00 to 17:00
Tuesday: 08:00 to 17:00
Wednesday: 08:00 to 17:00
Thursday: 08:00 to 17:00
Friday: 08:00 to 17:00
Saturday: 08:00 to 17:00
Thanks anyway.....
