08-17-2011 01:48 PM - edited 03-16-2019 06:32 AM
Hi buddys;
i am designing a VOIP solution, which dont need autoattendace nor voice mail , so i not included AIM "CUE" module
but i need to connect a FAX machine using FXS port and coulde use DID, IS CUE a MUST FOR THIS FAX CONNECTION??
also could you provide me why FAX Could need CUE?
so i have 2 questions
1-can FAX connected to FXS without CUE "AIM module", or not ??
2-What is the services can be delivered by CUE to FAX connectivity?
many thanks for your time
Solved! Go to Solution.
08-18-2011 09:45 PM
This is taken from this link:
I think this is what you are talking about. But if you're going to have your fax machine in the FXS there is no need of the CUE.
08-17-2011 08:41 PM
CUE isn't a must for using your fax machine.
Gabriel.
08-18-2011 03:39 AM
Thanks Gabriel, you r right, but i think there is some services cant be done without CUE, i mean FAX services, could anyoone till us about it.
08-18-2011 09:45 PM
08-24-2011 03:34 PM
Many thanks for you, my friend
