CUE and FAX
Ahmed Zein
Hi buddys;
     i am designing a VOIP solution, which dont need autoattendace nor voice mail , so i not included AIM "CUE" module
but i need to connect a FAX machine using FXS port and coulde use DID, IS CUE a MUST FOR THIS FAX CONNECTION??
also could you provide me why FAX Could need CUE?
so i have 2 questions
1-can FAX connected to FXS without CUE "AIM module", or not ??
2-What is the services can be delivered by CUE to FAX connectivity?
many thanks for your time
This is taken from this link:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps5520/product_data_sheet0900aecd806aefe4.html
Fax integration
Inbound  fax capability is provided using a combination of the native T.37 fax  processing in the Cisco Integrated Services Routers, combined with the  message management of Cisco Unity Express. You can receive faxes using a  single or a separate direct-inward-dialing (DID) number, and you can  store messages in your mailbox or have them sent to your email client as  a TIFF file attachment through the Internet Message Access Protocol  (IMAP) capability or delivered in a GDM. You can select a fax machine to  print the fax that is stored in a GDM or in your personal mailbox.
I think this is what you are talking about. But if you're going to have your fax machine in the FXS there is no need of the CUE.
CUE isn't a must for using your fax machine.
Gabriel.
Thanks Gabriel, you r right, but i think there is some services cant be done without CUE, i mean FAX services, could anyoone till us about it.
Fax integration
Many thanks for you, my friend
