11-07-2021 03:58 AM
I have done the configuration for the cme part and its working great, now I will have to configure the CUE. I have also done the basic configurations and I can also log on to the web interface,
I need to Enable AA feature, I precisely mean when an external call comes the greetings should work and it should ask the extension for 0 for reception, how do do this. I have no knowledge about this I have been searching and reading a lot but cisco doesn't really have step by step procedure for Auto Attendent. Can any one help me step by step procedure for this ?
11-07-2021 04:32 AM
11-07-2021 04:54 AM
Thanks I have already referred this document it show more about the voice mailboxes. It doesnt show to create pilot number for AA. Still there are lot of things missing in the document. Any more help will be appreciated.
11-07-2021 05:09 AM
Have a look on below Video and Document. You can make use of CUE default AA script. or You can modify the script using script editor.
https://www.youtube.com/watch?v=MGwJ6ZMTHc8
11-07-2021 09:54 PM
The video talks more about the CUE side but it doesnt really shows any thing on CME side where we should create the AA pilot number then setting the AA number in the Fxo for incoming calls.
