07-20-2015 07:33 AM - edited 03-17-2019 03:42 AM
Gents, I have nme-wae-502-k9,
For WAAS is it possible to install CUE 8.6 instead and how
07-20-2015 08:06 AM
Hi Zaher
For any Cisco Unity Express 8.6 install you will need an SRE Module.
Please see the compatibility matrix for the CUE
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.html
07-20-2015 12:04 PM
Thanks Wilson,
But I have 3845 ISR all Modules in the provided URL for 2900 and 3900
Cheers
07-20-2015 12:18 PM
Hi Zaher,
I am afraid, but CUE 8.6 is only supported on SREs and SREs are only supported on the 2900/3900s.
However if you can let me know the CCM version, we can update you with what is the highest version of CUE you can go on the existing 2800/3800 infra structure
07-20-2015 12:20 PM
Hi Wilson,
It's CUCM 9.1
07-20-2015 12:41 PM
Quick question, are you looking forward to Install CUE on WAAS Module or your question is if WAAS supports the existing CUE/CUCM integration?
07-20-2015 12:45 PM
Yes what i'm looking forward is to install CUE ver 8.6 on nme-wae-502-k9 WAAS module
Because this guy did it but on different module
https://supportforums.cisco.com/discussion/11828761/re-install-cue-86
Finally i found in below URL that NME-CUE supports 8.6 also it's compatible with 3800
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/compatibility/cuemigration.html
07-20-2015 12:57 PM
Yes, CUE is supported on NME-CUE module which is the newer version of NM-CUE.
However I am not sure if you would be able to install CUE 8.6 on WAAS module?
Please let us know if you can indeed install CUE 8.6 on a WAAS moduel
