CUE question
techguy
Level 4
Level 4
In order to sent call to CUCM, i have following options.
FXO Ports and CUE, i can configure CTI Route point and point it by plar connection.
E1 line and CUE, i can configure voip dial-peer and make destination pattern.
Lets say if i dont have CUE then and i have FXO lines. How can i manage to coonect it to CUCM.
I have made h323 gateway.
gmgarrian
Level 4
Level 4
CUE, Cisco Unity Express, really doesn't have anything to do with call routing.
To do what you're asking, create a dial peer to CUCM that the connection plar on the FXO port will match.
My phone extension is 2222. No outgoing and incoming call is working
voice-port 0/0/0
trunk-group FXO
input gain -3
output attenuation -1
echo-cancel coverage 64
no comfort-noise
connection plar 2222
music-threshold -45
bearer-cap Speech
dial-peer voice 4 pots
description Mobile
destination-pattern 955......
fax rate disable
port 0/0/0
prefix 55
dial-peer voice 6000 voip
preference 1
destination-pattern 2...
voice-class codec 1
voice-class h323 1
session target ipv4:10.X.X.X
dtmf-relay h245-alphanumeric
req-qos guaranteed-delay audio
acc-qos guaranteed-delay audio
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
