06-12-2013 02:12 PM - edited 03-16-2019 05:50 PM
Does anyone know we're I can find the maximum number of VPIM subscribers for the latest version of unity express?
Solved! Go to Solution.
06-12-2013 06:12 PM
Regardless of the license level, the CUE-NM-EC supports a maximum of 100 remote subscribers, the
CUE-NM supports a maximum of 50 remote subscribers, and the AIM-CUE supports a maximum of 20
remote subscribers.
Please see the below mentioned link.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_3/cliadmin/ch8netwk.pdf
Hope this helps.
Please rate helpful.
06-12-2013 06:12 PM
remote subscribers.
Hope this helps.
06-12-2013 06:18 PM
Thanks it seems i found it very difficult to find that document.
