CUE wizard fails at
jfawcett
I am configuring a CUE 8.6 integation with CME 8.6. When I Iaunch the CUE initialization wizard and configure the IP Address Web Admin Name and password it throws an error " Login to CUCME as an administrator failed. Check your CUCME configuration ". I have tried different accounts but none authenticate.
Any ideas ?
paolo bevilacqua
Can you login to CME GUI using a browser ?
paolo bevilacqua
Hi Paolo
Good call, I could not login to http://ipaddress/ccme.html so I re-installed the GUI files to flash:/GUI
set the path
ip http path flash:/GUI
and it all worked successfully
I was initially using Cisco Configuration Professional, so never actually checked the CME GUI.
Jamie
Very good, thanks for the nice rating and good luck!
