CUMA IPhone Error Certificate
Hello
I have an IPhone3G with Moibile Communicator 7.1.4, but when I Try to connect to the CUMA Server I get a error message "Invalid Certificate (1204)"
The Connection is trough an ASA, In the ASA I Have a Verisign Certificate.
Any Idea for This.
Regards.
Here are just a few thoughts.
Are you connecting from the internal enterprise network ? This will not work since you don't connect to the external ASA interface.
What are you using to connect to ASA ? IP address or FQDN? It should match the one the certificate is issue for
Can you download openssl and see what certificate you will be presented with ?
Here the command you use
openssl s_client -connect cuma.com:5443 where cuma.com is the fqdn/ip address you use in your iphone.
You should be presented with the verisign certificate.
Christos
We are having the same issues with 2 Cuma installs, different customers, different firewalls, but both have the same errors.  Ran a debug while doing the openssl.
CRYPTO_PKI: No suitable trustpoints found to validate certificate serial number:
I get this as the last line that shows the full subject name, which matches the trustpoint.
I get this as the last line in the openssl command
  Verify return code: 19 (self signed certificate in certificate chain)
Now here is a question that is bugging me. The hostname of the ASA is different than the hostname used for Cuma connections. Will that cause an issue?
mnour401917_2
Did you end up fixing your issue, i have the same problem.
Mohammed
