Custom ringtone for Single Phone
vinayjaiswal
Level 3
Level 3
I am trying to to use the custom ring for different users, when i make the changes to Ringlist.xml and upload the changes are reflected on all the phones, is there any to change only individual phones. I am using CUCM version 7.1.5.
Vinay
Just to add something, there is no way to restrict that only certain phones can look at the ringtones.
Any phone that has the same TFTP configured will look at the same ringlist.xml file and be able to use the ringtone.
So, the only way to configure a ringlist.xml file and have only 1 phone look at it is to configure a dedicated TFTP server for just that phone.
If that's for only 1 phone the best way as previously mentioned is phone designer.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Fadhu Mohamed
Hello Vinay,
You should try using Cisco IP Phone Designer(download using ur CCO). You can assign ringtones and wallpapers to any phone in your cluster. Make sure phone personalization is enabled on the phone(or much better in the "enterprise parameters")
Cheers
Fadhu Mohamed
java
java
thanks a lot, java.
What about using a custom TFTP server? We are using 3rd Party Controlled MPP series phones and would like to have a custom TFTP server for ringtones. Is this possible?
