customize the UI of Cisco jabber client
Is there any way  customize the UI of Cisco jabber client or modify the look of it and is it possible to add the logo of my company
Jaime Valencia
No, that's not possible.
There are a few options for colors you can choose, and the old Jabber look, but that's about it.
java
if this helps, please rate
Jaime Valencia
java
Even I can't change wall paper?
