dail-peer not working
sdaniels44
Dial peer 14 is not working:
http://pastebin.ca/1281736
debug voice dialpeer inout:
Dec 10 16:30:47.846: //-1/BC172FC2B698/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=103
Dec 10 16:30:47.850: //-1/BC172FC2B698/DPM/dpMatchPeersCore:
Calling Number=, Called Number=2142346837, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=2142346837
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Dec 10 16:30:47.850: //-1/BC172FC2B698/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
allan.thomas
Level 8
Level 8
Hi Shaun, when you show dial-peer voice summary, what is the status of the dial-peer 114? Up or Down?
What I have noticed is that the trunk group label that you have assigned does not have any active voice-ports. Therefore I suspect that it is down.
Should the trunkgroup label be 'trunkgroup Local' and NOT 'trunkgroup local'?
Hope this helps
Allan.
allan.thomas
Level 8
Level 8
Hope this helps
Allan.
Im an idiot, thanks for your help.
local should have been Local. It is case sensitive.
You were right.
