Bookmark
Subscribe
8383
Database replication issue - incorrect publisher hostname
Alex Alp Bahar
After changing the hostname of all servers (CUCM 7.1.5), I ended up with database replication issue.
Database status report shows that the subscriber still refers to the old publisher hostname although ip addresses are updated.
I ran utils dbreplication stop,  utils dbreplication reset all, then restarted the subscriber.
RTMT database summary shows publisher replication status 2.
But subscriber replication all attributes are blank. As if there is no subscriber.
What is the quickest and best way to fix this replication issue? All licences etc are installed, but the subscriber server is not in production yet. I am happy to rebuild the subscriber server if this is the best option. I appreciate your advice.
SUBSCRIBER:
admin:utils dbreplication status
-------------------- utils dbreplication status --------------------
connect to auhodccm01_ccm7_1_5_30000_1 failed      <<<<<===== This is the subscriber itself
Enterprise Replication not active  (62)
command failed -- unable to connect to server specified  (5)
Replication status check is now running in background.
Use command 'utils dbreplication runtimestate' to check its progress
The final output will be in file cm/trace/dbl/sdi/ReplicationStatus.2011_06_30_12_38_56.out
Please use "file view activelog cm/trace/dbl/sdi/ReplicationStatus.2011_06_30_12_38_56.out " command to see the output
admin:file view activelog cm/trace/dbl/sdi/ReplicationStatus.2011_06_30_12_38_56.out
No Errors or Mismatches found.
Replication status is good on all available servers.
utils dbreplication status output
To determine if replication is suspect, look for the following:
        (1) Number of rows in a table do not match on all nodes.
        (2) Non-zero values occur in any of the other output columns for a table
connect to syscdr@auhodccm01_ccm7_1_5_30000_1 failed
Error Details:
I copied the database summary report that shows the mismatch on subscriber.
10.1.6.130
#This file was generated by the /etc/hosts cluster manager.
#It is automatically updated as nodes are added, changed, removed from the cluster.
127.0.0.1 localhost
::1 localhost
10.1.6.130  AUOPDCCM01
10.23.34.10  AUHODCCM01
10.23.34.10
127.0.0.1 localhost
::1 localhost
10.1.6.130  AUDCHOMCCM01
Serverrhosts File
10.1.6.130
localhost
AUHODCCM01
AUOPDCCM01
10.23.34.10
localhost
AUDCHOMCCM01
AUHODCCM01
Checks the contents of the sqlhosts file on each installed server and returns a summary checking to see if they are equivalent.
ErrorThe sqlhosts file on 10.23.34.10 does not match the publisher.
Expand MeView Details
Serversqlhosts File
10.1.6.130
g_hdr     group     -     -     i=1
g_auopdccm01_ccm7_1_5_30000_1     group     -     -     i=2
auopdccm01_ccm7_1_5_30000_1     onsoctcp     10.1.6.130     auopdccm01_ccm7_1_5_30000_1     g=g_auopdccm01_ccm7_1_5_30000_1 b=32767,rto=300
g_auhodccm01_ccm7_1_5_30000_1     group     -     -     i=4
auhodccm01_ccm7_1_5_30000_1     onsoctcp     10.23.34.10     auhodccm01_ccm7_1_5_30000_1     g=g_auhodccm01_ccm7_1_5_30000_1 b=32767,rto=300
10.23.34.10
g_hdr     group     -     -     i=1
g_audchomccm01_ccm7_1_5_30000_1     group     -     -     i=2
audchomccm01_ccm7_1_5_30000_1     onsoctcp     10.1.6.130     audchomccm01_ccm7_1_5_30000_1     g=g_audchomccm01_ccm7_1_5_30000_1 b=32767,rto=300
Alp
Alex Alp Bahar
ON THE PUBLISHER:
The final output will be in file cm/trace/dbl/sdi/ReplicationStatus.2011_06_30_12_53_22.out
Please use "file view activelog cm/trace/dbl/sdi/ReplicationStatus.2011_06_30_12_53_22.out " command to see the output
admin:file view activelog cm/trace/dbl/sdi/ReplicationStatus.2011_06_30_12_53_22.out
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_auopdccm01_ccm7_1_5_30000_1    2 Active   Local           0
Processing ccmdbtemplate_auopdccm01_ccm7_1_5_30000_1_1_95_typedberrors with 993 rows group 1
Sync target server is not defined for the replicate ccmdbtemplate_auopdccm01_ccm7_1_5_30000_1_1_95_typedberrors
command failed -- participants required for operation specified  (17)
end of the file reached
srsivara
On each sub's os admin page, is settings > ip > publisher set to the correct host name of the pub ? If not set it up, reboot one sub at a time and then check dbrep status. You might have to stop replication on all servers, and then a reset all from the pub after that.
Thanks for your reply.
I have followed this blog http://vannis.tk/?p=316 to fix the issue.
Alp
