debug ccsip messages not showing output
monasir
Hi all,
Im facing something strange, when im doing " debug ccsip messages" and after that term mon
I don't seeing any output coming by in the cube.
This has been worked before, i was checking the configurution ive noticed the command logging buffered 1000000 was missing.
Configured it but still dont see anything.
no logging queue-limit
no logging rate-limit
no logging console
no logging monitor
logging monitor 7 command fixed the issue.
Conf t
Logging monitor 7
Exit
9 Replies 9
Dennis Mink
Yes it can be flaky at times. Do term mon and log your client input and put in logging console
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis,
Im not understanding , what exactly do you mean with log your client input?
So for instance if you use putty. Go to session settings and choose log session so it gets written to a file so you can analyze debug info
Ok clear,
Is there a reason why its not showing the output in the cube?
Are you making a test call in and running term mon and logging console configured? Whenrunning the debug?
Hi Dennis,
Debug ccsip message is active - term mon
And then im making a test call, like it should be
Still not showing output
if you are using the below config, then you should use "sh log" command to see logs.
no logging console
no logging monitor
Conf t
Logging monitor 7
Exit
