IP Telephony and Phones
Labels
Unfortunately, the following options on my Cisco phone no longer work:Function: DirectoriesI do not see any missed callsAnswered callsDialed numbersPersonal directoryCorporate DirectoryThe redial does not work eitherI use a Cisco phone 7962 Note : Lo...
Dears   i have configure the core switch as  NTP server for my ip phones. It take the time just fine but i notice that the time in the core switch is not accurate so now i need to change the time in the core (NTP server) so once i change the time in ...
I have different types of Cisco IP phones 7975 7962 7960 7942 7911 6942 all of them are registered to CME 11.7the issue is when I press directories button to see call history(missed calls, received calls placed calls) I see "xml error 4 parse error" ...
I have a Non Cisco SIP Device that can integrate directly with the Cisco CM with no uses. The device does use a COPs device definition and does not use the default 3rd party devices (Not sure if that matters).    I would like to setup an Expressway E...
mark50 by Level 1
  • 1186 Views
  • 3 replies
