Debug ISDN q931 help: What are Channel 30 and 35 on a QSIG trunk?
calicolin1
I have two serial interfaces on a 3925 configured as QSIG trunks connecting to a Nortel Meridian. The config for each interface is given below. There are 23 B channels plus 1 D channel on each trunk. But according to the debug isdn q931, I see calls taking Channels 30 and 35? What gives?
interface Serial0/0/2:23
 description To-Nortel-Loop-6
 no ip address
 encapsulation hdlc
 isdn switch-type primary-qsig
 isdn timer T310 120000
 isdn protocol-emulate network
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 no cdp enable
interface Serial0/0/3:23
 description To-Nortel-Loop-7
 no ip address
 encapsulation hdlc
 no cdp enable
Jul  8 17:30:35.408: ISDN Se0/0/2:23 Q931: TX -> SETUP pd = 8  callref = 0x7AC2
        Sending Complete
        Bearer Capability i = 0xA880
                Standard = ISO/IEC
                Transfer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = Packet - not specified
        Channel ID i = 0xAC
                Exclusive, Channel 35
        Facility i = 0x9FAA06800100820100A11802025CD7020151300FA50A0A0100120536393533300A0120
        Calling Party Number i = 0x0081, '42'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '9530'
Jul  8 17:30:35.476: ISDN Se0/0/2:23 Q931: RX <- CALL_PROC pd = 8  callref = 0xFAC2
        Channel ID i = 0xAC
                Exclusive, Channel 30
Jul  8 17:30:35.516: ISDN Se0/0/3:23 Q931: RX <- SETUP pd = 8  callref = 0x0E38
        Sending Complete
                Standard = ISO/IEC
        Channel ID i = 0xAC
        Calling Party Number i = 0x80, '42'
        Called Party Number i = 0x89, '69530'
                Plan:Private, Type:Unknown
Jul  8 17:30:35.524: ISDN Se0/0/3:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8E38
        Channel ID i = 0xAC
                Exclusive, Channel 0
Jul  8 17:30:35.528: ISDN Se0/0/3:23 Q931: TX -> SETUP pd = 8  callref = 0x5352
        Sending Complete
                Standard = ISO/IEC
        Channel ID i = 0xAC
        Calling Party Number i = 0x0083, '4242'
Jul  8 17:30:35.648: ISDN Se0/0/3:23 Q931: RX <- CALL_PROC pd = 8  callref = 0xD352
        Channel ID i = 0xAC
8 Replies 8
From the logs I can see that you are using T1 PRI. By default Cisco PRI routers use descending channel selection. This means that channels 30 is your 1st channel which the IOS router is using to communicate with your telco. Channel 35 is the channel selected by your telco to signal your router. Usually the telcos use NFAS to provide large pool of channels.
But there are only 23 channels on each PRI. NFAS is not implemented here. I must be missing something.. how can 30 and 35 be used on a 23 channel PRI?
Can you share the output of show inventory from your router?
sh inventory
NAME: "CISCO3925-CHASSIS", DESCR: "CISCO3925-CHASSIS"
PID: CISCO3925-CHASSIS , VID: V02, SN: FTX...
NAME: "Cisco Services Performance Engine 100 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 100 for Cisco 3900 ISR"
PID: C3900-SPE100/K9   , VID: V06 , SN: FOC...
NAME: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-4MFT-T1/E1  , VID: V01 , SN: FOC...
NAME: "PVDM3 DSP DIMM with 128 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 128 Channels"
PID: PVDM3-128         , VID: V01 , SN: FOC...
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC       , VID: V04 , SN: QCS...
NAME: "C3900 AC Power Supply 2", DESCR: "C3900 AC Power Supply 2"
This is really interesting, could you please post the following outputs:
1. sh isdn status
2. sh run from the router
sh isdn status
Global ISDN Switchtype = primary-ni
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/2:23 interface
        ******* Network side configuration *******
        dsl 0, interface ISDN Switchtype = primary-qsig
         **** Master side configuration ****
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x807FFFFF
    Number of L2 Discards = 0, L2 Session ID = 70
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 1. Layer 3 output may not apply
ISDN Serial0/0/3:23 interface
        dsl 1, interface ISDN Switchtype = primary-qsig
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 1 CCBs = 0
    Number of L2 Discards = 0, L2 Session ID = 164
    Total Allocated ISDN CCBs = 0
sh run
Building configuration...
Current configuration : 6543 bytes
version 15.2
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
service password-encryption
hostname vg1...
boot-start-marker
boot system flash:c3900-universalk9-mz.SPA.152-4.M7.bin
boot system flash:c3900-universalk9-mz.SPA.152-4.M6a.bin
boot-end-marker
card type t1 0 0
logging buffered 8000000
enable secret 5 $1$
aaa new-model
aaa group server tacacs+ tacgroup
 server 172.
aaa session-id common
clock timezone PST -8 0
clock summer-time PDT recurring 2 Sun Mar 2:00 2 Sun Nov 2:00
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
network-clock-select 3 T1 0/0/2
network-clock-select 4 T1 0/0/3
ip cef
no ipv6 cef
isdn switch-type primary-ni
voice-card 0
voice service voip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
voice translation-rule 1
 rule 1 /^42/ //
voice translation-profile Voice
 translate called 1
license udi pid C3900-SPE100/K9 sn FOC18349XQG
hw-module pvdm 0/0
redundancy
controller T1 0/0/0
 shutdown
 cablelength long 0db
controller T1 0/0/1
 shutdown
controller T1 0/0/2
 pri-group timeslots 1-24 service mgcp
 description Nortel Loop 40
controller T1 0/0/3
 description Nortel Loop 41
class-map match-any AutoQoS-VoIP-RTP-Trust
 match ip dscp ef
class-map match-any AutoQoS-VoIP-Control-Trust
 match ip dscp cs3
 match ip dscp af31
policy-map AutoQoS-Policy-Trust
 class AutoQoS-VoIP-RTP-Trust
  priority percent 70
 class AutoQoS-VoIP-Control-Trust
  bandwidth percent 5
 class class-default
  fair-queue
interface Embedded-Service-Engine0/0
 no ip address
 description To LAN
 ip address 172.30.189.101 255.255.255.0
 ip pim sparse-dense-mode
 duplex auto
 speed auto
 service-policy output AutoQoS-Policy-Trust
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
 description To-Nortel-Loop-40
 no ip address
 encapsulation hdlc
 no cdp enable
 description To-Nortel-Loop-41
 no ip address
 encapsulation hdlc
 no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 172.
logging trap debugging
logging host 172.
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/0/2:23
voice-port 0/0/3:23
ccm-manager fallback-mgcp
ccm-manager redundant-host ucmsub2
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
mgcp
mgcp call-agent ucmsub1 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate domain-name
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 1 pots
 translation-profile incoming Voice
 service mgcpapp
 port 0/0/2:23
dial-peer voice 2 pots
 service mgcpapp
 port 0/0/3:23
sip-ua
 timers trying 100
gatekeeper
 shutdown
alias configure e end
alias exec c configure term
alias exec sr show run
alias exec sb show ip int br
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 0 0
 privilege level 15
 transport input telnet ssh
line vty 5 15
 exec-timeout 30000 0
 privilege level 15
scheduler allocate 20000 1000
ntp server time1.
end
Certainly seen for the first time about the channel numbers.
Have you tried to reload and see if it makes any difference?
In fact in my initial response, I was under impression that it is E1 instead of T1 which made it was normal to me to see channel 30. But with T1 this is very confusing.
Can you share the output of you CUCM MGCP configuration? Also, try to reload the router as Wilson mentioned.
