debug isdn q931 "no route to destination"
monasir
Ä customer is trying to call numbers to ukrain, but all the calls are failing.
When I debug in the mgcp gateway I i'm getting"a "  Cause i = 0x8283 - No route to destination "
When the customers calls to other countrys it works fine.
Seems it only happens when they call numbers to ukrain.
dialed number analyzer is saying that it should route this pattern.
I'm a little bit lost now
8 Replies 8
Jitender Bhandari
Can you provide the full debug for a call from the router.
debug isdn q931
debug MGCP packet
JB
I have checked with the customer again.
Now it seems that they are not able to call numbers in the area code of Kiev (oekrain)
Other numbers in oekrain are working.
so that means numbers in this range 000.38 (44) are not routing out of the GW.
It hits the GW, but not getting out.
however I have attached the packet of the calls that's works and not.
I see the disconnect coming from service provider.
*Aug 14 17:03:41: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0080
	Sending Complete
	Bearer Capability i = 0x8090A3
		Standard = CCITT
		Transfer Capability = Speech
		Transfer Mode = Circuit
		Transfer Rate = 64 kbit/s
	Channel ID i = 0xA9839F
		Exclusive, Channel 31
	Calling Party Number i = 0x0081, '2200670'
		Plan:Unknown, Type:Unknown
	Called Party Number i = 0x80, '0442300700'
*Aug 14 17:03:41: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8080
*Aug 14 17:03:41: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8080
	Progress Ind i = 0x8288 - In-band info or appropriate now available
Which means either its a provider issue, or you are not sending the number in correct format to ISP. Do you think you are sending the correct format for number your ISP is expecting. If you are not sure you need to call them and they can tell you how they would like to receive the number.
(Rate if it helps)
JB
Hi JB,
According to the customer all the other area codes to Ukrain works fine.
Except (044)  they get  no exsist tone.
Can you attach the above debugs for a working call.
JB
please find attached working phone calls for ukrain.
I think this is a service provider issue as i dont see lot of difference in working and non-working debugs. But in the non-working we receive disconnect from service provide, have you asked your service provider about this, bu showing thim this debug?
(Rate if it helps)
JB
I gave the customer ( a client of us)  advise to contact the SP.
Because we don't have contact with the SP.
I'm curious what they say.
However i'm thanking you with the extra thinking!
If there is new information I will update you
