Showing results forĀ
Search instead forĀ
Did you mean:Ā
Decoding pcm.dat
JohnNetEng
I've got a Cisco 2821 running 12.4(13r)T11 and created a capture on our PRI, using the following commands
voice hpi capture buffer 50000000
voice hpi capture destination flash:pcm.dat
test voice port 0/0/0:23.1 pcm-dump caplog 7 duration 255
I made a test call and ftp'd the pcm.dat to my laptop and thought I'd give it a shot extracting the audio using Audacity in the instructions listed here:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-system/115749-analyze-pcm-data.html
However, I just here an incessant drone. Do the instructions for Audacity in the above hyperlink only apply to the pcm-tracer command in the ISR2 and newer routers?
Additionally, can the pcm.dat files only be decoded by TAC?
John
Nadeem Ahmed
The decoding tool used by Cisco TAC guy and not available open for all(publicily) that's the sad part.
you might need to open a TAC case just to get this decoded or you have any issue in respect to that.
Br,
Nadeem Ahmed
PS: Please rate all useful post
Br, Nadeem Please rate all useful post.
