Default Cisco Unified Communications Manager User Data Service (UDS) port
mramirez-t
I need to work with someone to set up Blackberry Enterprise Server to work with Jabber.  One of the prereqs in this is to find out what port the UDS works on.  I haven't been able to find a definitive answer.  My guess is 8443 based on this doc, which I thought would show it but doesn't.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/port/9_0_1/CUCM_BK_T98E8963_00_tcp-port-usage-guide-90/CUCM_BK_T98E8963_00_tcp-port-usage-guide-90_chapter_01.html
Jaime Valencia
Take a look at this bug CSCve02996
java
if this helps, please rate
Jaime Valencia
java
Thank you!
