08-18-2011 05:05 AM - edited 03-16-2019 06:33 AM
I am working on a issue for a customer where when a caller makes an outbound call, there is a delay of 8-10seconds before the caller hears rinback tone. I have made interdigit timeout to 2 but still the same issue. Are there any settings which can reduce this time?
Some details:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(2)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 11-Aug-10 13:38 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
CTBRDCME01 uptime is 12 weeks, 6 days, 4 hours, 37 minutes
System restarted at 08:25:18 BST Fri May 20 2011
System image file is "flash0:c2900-universalk9-mz.SPA.151-2.T1.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco CISCO2901/K9 (revision 1.0) with 466944K/57344K bytes of memory.
Processor board ID FHK143572X3
2 Gigabit Ethernet interfaces
2 ISDN Basic Rate interfaces
1 terminal line
2 Voice FXO interfaces
2 Voice FXS interfaces
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
Cisco Unity Express 8.0.2 in slot 0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2901/K9 FHK
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
voice-port 0/2/0
translation-profile incoming BT-ISDN-IN
compand-type a-law
cptone GB
description ### ISDN2e circuit ###
bearer-cap Speech
dial-peer voice 10 pots
description ** All Calls **
destination-pattern .T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/2/0
forward-digits all
CONFIG (Version=8.1)
Version 8.1
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 10.63.3.110 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
no auto-reg-ephone
load 7921 CP7921G-1.3.4
max-ephones 20
max-dn 50
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
voicemail 249
cnf-file location: flash:
cnf-file option: PER-PHONE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
phone service thumbButton1 PTTH3
time-format 24
date-format dd-mm-yy
timezone 21 GMT Standard/Daylight Time
secondary-dialtone 9
url services http://10.63.x.x/voiceview/common/login.do
url authentication http://10.63.x.x/CCMCIP/authenticate.asp
call-forward pattern .T
call-forward system redirecting-expanded
transfer-pattern 9.T
keepalive 30 auxiliary 30
timeout interdigit 2
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message The House Telephony
edit DN through Web: enabled.
edit TIME through web: disabled.
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp Jan 01 2002 00:00:00
transfer-system full-consult
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
08-18-2011 05:14 AM
Please provide some debugging information for ISDN by turning the "debug isdn q931" on the CME.
12-29-2012 02:33 PM
You need to ajust the pattern digit length for each dial-peer posts for outbound calls.
regards
12-29-2012 04:30 PM
I the UK we have a variable length numbering scheme.
You weill need to write your dial peers for out going
calls to match at least the most common tye patterns or
rely on the T302 timer
Something like this :-
dial-peer voice 101 pots
description ** EMERGENCY **
destination-pattern 999
port 0/2/0
forward-digits all
dial-peer voice 102 pots
destination-pattern 112
port 0/2/0
forward-digits all
dial-peer voice 103 pots
description ** NATIONAL **
destination-pattern 0[1-2].........
port 0/2/0
forward-digits all
dial-peer voice 104 pots
description ** MOBILE **
destination-pattern 07.........
port 0/2/0
forward-digits all
! etc etc
dial-peer voice 111 pots
description ** INTERNATIONAL **
destination-pattern 00T
port 0/2/0
forward-digits all
