delete CDR records
mymite060708
What is the best way to delete CDR logs from the CDR database on callmanager, I need to remove all CDR logs from last year
jbarcena
Level 9
Level 9
Try a manually purge of the CDR database, login to CAR and go to System --> Database --> Manual Purge. In there you can select to delete all the files prior a designated date.
//Jorge
