Destination country ring back not received by calling phone
mgbrown007
Hi All, I've seen some information on this topic but nothing that quite matches my situation yet.
CUCM 8.6 -> SIP TRUNK -> SME 8.6 -> SIP TRUNK -> 3925 -> PRI
What we are experiencing is that all outbound calls hear the say alerting ring back tone localized to the CUCM cluster regardless of the destination country that is called.  At some point the CUCM/SME or gateway must be generating the alerting tone before the audio from the carrier is cutting through.  I've tried several different things but can't seem to come up with the correct combination of settings to make it work.  The situation is the same for two separate new CUCM cluster, one in the US and one in the UK.  All calls outbound from the US hear US ringback and all calls outbound from the UK hear UK ringback.  I'm sure it's something simple that I must be overlooking and any assistance is appreciated.  Some relevant config shown below.
-Mike
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  header-passing
  error-passthru
  registrar server
  early-offer forced
  midcall-signaling passthru
dial-peer voice 2001 pots
description *Outbound International*
destination-pattern 00[1-9]
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/0:15
forward-digits all
5 Replies 5
radoslav-drabik
This should help.
voice-port 0/0/0:15
cptone GB
Rate if it helps.
Thanks, tried that.  No change.
paolo bevilacqua
Can you remove all the progress_ind commands, and post "debug isdn q931" "debug ccsip message" for a call when you receive the "wrong ringback". Do not take other debugs, do not use attachments.
Hi Paolo, Here's the updated config on the dial peer.  Very basic at this point.
port 0/0/0:15
forward-digits all
Call flow is: Phone in the UK set with UK Network Locale, dialing out through a local UK gateway via E1 PRI to a destination in the US. (external number mask of +49... is just for some other testing)  Calling phone only hears UK ringback, and never the US ringback from the destination switch.
The SIP Trunk Profile from SME to the 3925 gateway is set as follows:
- Disable Early Media on 180 [Unchecked]
- SIP Rel1XX Options [Send PRACK if 1XX contains SDP]
The SIP trunk itself is set with MTP Required.
------Debug Output------------
1526379: Dec  7 18:22:29.427 GMT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+18052362881@10.32.254.32:5060 SIP/2.0
Via: SIP/2.0/TCP 10.32.3.9:5060;branch=z9hG4bK5410c788f0bda
From: "Mike Brown" <>;tag=686362~3c8ec1be-54ea-4c9f-b3ce-f353addaa6bf-43278881
To: <>
Date: Fri, 07 Dec 2012 18:22:29 GMT
Call-ID: dc36600-c2133e5-53cf7-903200a@10.32.3.9
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Cisco-Guid: 0230909440-0000065536-0000000242-0151199754
Session-Expires:  1800
P-Asserted-Identity: "Mike Brown" <>
Remote-Party-ID: "Mike Brown" <>;party=calling;screen=yes;privacy=off
Contact: <>
Max-Forwards: 69
Content-Type: application/sdp
Content-Length: 211
v=0
o=CiscoSystemsCCM-SIP 686362 1 IN IP4 10.32.3.9
s=SIP Call
c=IN IP4 10.32.254.31
t=0 0
m=audio 27264 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
1526380: Dec  7 18:22:29.431 GMT: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num +496927223224
1526381: Dec  7 18:22:29.431 GMT: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0196 callID = 0x8117 switch = primary-net5 interface = User
1526382: Dec  7 18:22:29.431 GMT: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0196
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Display i = 'Mike Brown'
        Calling Party Number i = 0x0181, '+496927223224'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '0018052362881'
1526383: Dec  7 18:22:29.431 GMT: //589/0DC366000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <>
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
1526384: Dec  7 18:22:29.603 GMT: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8196
1526385: Dec  7 18:22:33.399 GMT: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8196
        Progress Ind i = 0x8482 - Destination address is non-ISDN
1526386: Dec  7 18:22:33.411 GMT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <>;tag=47B9FB18-1227
CSeq: 101 INVITE
Require: 100rel
RSeq: 2762
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <0018052362881>;party=called;screen=no;privacy=off
Contact: <>
Supported: sdp-anat
Content-Disposition: session;handling=required
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 7284 8654 IN IP4 10.32.254.32
s=SIP Call
c=IN IP4 10.32.254.32
t=0 0
m=audio 23890 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
1526387: Dec  7 18:22:33.411 GMT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:+18052362881@10.32.254.32:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.32.3.9:5060;branch=z9hG4bK5411275b5cc4a
CSeq: 102 PRACK
RAck: 2762 101 INVITE
Max-Forwards: 70
Content-Length: 0
1526388: Dec  7 18:22:33.411 GMT: //589/0DC366000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 07 Dec 2012 18:22:33 GMT
CSeq: 102 PRACK
Content-Length: 0
1526389: Dec  7 18:22:39.627 GMT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:+18052362881@10.32.254.32:5060 SIP/2.0
To: <>
CSeq: 101 CANCEL
Max-Forwards: 70
Content-Length: 0
1526390: Dec  7 18:22:39.627 GMT: //589/0DC366000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <>
Date: Fri, 07 Dec 2012 18:22:39 GMT
CSeq: 101 CANCEL
Content-Length: 0
1526391: Dec  7 18:22:39.635 GMT: //589/0DC366000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Reason: Q.850;cause=16
Content-Length: 0
1526392: Dec  7 18:22:39.635 GMT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+18052362881@10.32.254.32:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
1526393: Dec  7 18:22:39.647 GMT: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0196
        Cause i = 0x8090 - Normal call clearing
1526394: Dec  7 18:22:39.835 GMT: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8196
1526395: Dec  7 18:22:39.835 GMT: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0196
The trace seems OK to me.
I think you need to take a capture of the media to confirm what it is. If (as I suspect) is UK tone, then telco is generating it, and you cannot do anything about beside complaining to them.
