03-12-2012 11:59 AM - edited 03-16-2019 10:05 AM
I was looking through the various dial peers on my network and came accross one with a destination pattern of A9T. What does the A signify? I see in documentation statements that A through D are valid along with 0 through 9, comma, pound or period.I know what all the others mean and explanations for those are simple but I have not found anything in the documents about the A through D. I wouldn't think it would be a way to proritize the dial-peers since there is already a seperate command for that.
Referenced Documentation is at http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dp_confg.html#wp1067014
03-12-2012 12:11 PM
Is this GW with CUCM deployment to differentiate calls for trunk selection? perhaps A was added as a "steering code", see if you have any matching route patterns on CUCM.
HTH,
Chris
03-12-2012 12:27 PM
This is a H323 gateway configured with CUCM. I've looked through all my route patterns that point to that gateway and find none with an A in them or anything in the route groups or route lists that would ad the letter to the begining of the outgoing dial string.
On this gateway there is one PRI and a 2 port FXO card. The odd A9T destination pattern points to the FXO whereas there is a 9T destination pattern pointing to the PRI. In my other offices where there are both PRI and analog trunks, the preference command has been used to make the PRI be used first.Truthfully, that office is too small to even consume their entire PRI. I am assuming the analog line was meant to be a backup of some sort.
So based on your response, using A,B,C or D can be used in conjuction with some dialed number manipulation in CUCM to allow the direction of calls out particular trunks?
03-12-2012 12:30 PM
Correct, as phones are unable to character A, but it is a supported dial character.
HTH,
Chris
