04-08-2008 06:26 AM - edited 03-15-2019 09:55 AM
Is there a way/command to determine (from the router)the maximum number of smultaneous calls that have run through a 3825 Voice Gateway? IOS is currently 12.4(19). Thanks in advance.
04-08-2008 06:33 AM
Do you have CM ? If so, it can produce many statistics of this type.
Else, you can monitor the ISDN MIB with any snmp tools and it will produce a graph of channel usage over time.
04-08-2008 06:36 AM
We have CM but I would rather determine from the router side as I am on Network Side of house and I don't want to interfere with phone guys. The ISDN MIB might work for me - do you have any additional info on it?
04-08-2008 06:47 AM
ISDN MIB:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-ISDN-MIB
Watch out that if you're using MGCP, I'm not sure if that would work.
04-08-2008 06:46 AM
It doesn't appear that ISDN MIB RFC 2127 is available for the 3825 platform. Do you know for a fact that it is. It all appears that it is only available for BRI connect. We currently utilize PRI.
04-08-2008 06:51 AM
Yes it is, you worry not. Now checking better I think the MIB is this one:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=ISDN-MIB
