Determine which DTMF is negotiated
Good day
CUBE---------dtmf ?----------Third Party Server
I would like to know what DTMF is negotiated on a CUBE by looking at Debugs.
I configured dtmf sip-info (out of band) on a dial-peer linking to a 3rd party server.
The 3rd party server administrator claims he is receiving inband dtmf, but he should be receving sip-info dtmf (out of band)
You will find bellw the debug CCSIP message that includes the sdp sent by the CUBE and the sdp received from the 3rd party
How can I know if sip-info or sip-notify or rtp-nte was negotiated ?
1373372: *Aug 22 21:37:03.609: //279311/C34DF8EC9940/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:*30018322148610@198.20.53.102:5060 SIP/2.0
Via: SIP/2.0/UDP 198.20.55.250:5060;branch=z9hG4bKA61421574
From: "Telecom" <sip:+16134531300@cube2>;tag=1758F4B4-2556
To: <sip:*30018322148610@198.20.53.102>
Date: Sat, 22 Aug 2015 21:37:03 GMT
Call-ID: C34E4700-484C11E5-9946DFEA-8EA6030D@cube2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3276667116-1212944869-2571165674-2393244429
User-Agent: Cisco-SIPGateway/IOS-15.4.3.M3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1440279423
Contact: <sip:+16134531300@198.20.55.250:5060>
Expires: 60
Allow-Events: telephone-event
Max-Forwards: 18
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 194
v=0
o=CiscoSystemsSIP-GW-UserAgent 1179 6211 IN IP4 198.20.55.250
s=SIP Call
c=IN IP4 198.20.55.250
t=0 0
m=audio 19986 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
1373373: *Aug 22 21:37:03.613: //279311/C34DF8EC9940/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 trying -- your call is important to us
CSeq: 101 INVITE
Server: Semafone CCM V.3.1.4
Content-Length: 0
1373374: *Aug 22 21:37:03.617: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:*30018322148610@198.20.55.251:5060 SIP/2.0
Record-Route: <sip:198.20.53.134;r2=on;lr=on;ftag=1758F4B4-2556;TenantID=A>
Record-Route: <sip:198.20.53.102;r2=on;lr=on;ftag=1758F4B4-2556;TenantID=A>
Via: SIP/2.0/UDP 198.20.53.134;branch=z9hG4bK4f3f.c3f014181b86bfbeb1d90d35cccb4fbd.0
Min-SE:  1800
CSeq: 101 INVITE
Expires: 60
SEMA-DPM-Target: http://198.20.53.11:8443
Max-Forwards: 16
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
1373375: *Aug 22 21:37:03.619: //279312/C34DF8EC9940/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 198.20.53.134;branch=z9hG4bK4f3f.c3f014181b86bfbeb1d90d35cccb4fbd.0,SIP/2.0/UDP 198.20.55.250:5060;branch=z9hG4bKA61421574
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-15.4.3.M3
Content-Length: 0
Jaime Valencia
Read this
https://supportforums.cisco.com/document/113271/understanding-sip-traces
https://andrewjprokop.wordpress.com/2013/09/27/dtmf-and-rfc-2833-4733/
https://andrewjprokop.wordpress.com/2014/04/21/the-anatomy-of-an-invite-request/
java
if this helps, please rate
daniel.bloom
An easy command you can use to view the negotiated DTMF relay on a SIP call is
show sip calls
You can view a list of active calls using the
show sip calls brief
gosselic
It is clear from the the SIP messages that you are negotiating in-band audio (no dtmf relay).
I see that the 3rd-party server is a Semafone component called CCM. When integrating Semafone with a Cisco CUBE, you should use SIP-Notify as the DMTF relay.
Be sure to validate what kind of DTMF relay conversions you are doing form start to finish (first-incoming-leg to last-outgoing-leg) because some direct conversions are not supported in CUBE and you'll require some DSP support.
Good luck!
james.buchanan1
I'm working on a new Semafone configuration, and the problem I'm having is getting the digits to be masked to the agent's phone. I'm using rtp-nte from the provider and to CVP, and SIP-Notify to the Semafone server. However, no matter what I do, the agent still hears the DTMF tones. I'd be glad for any configuration snippets that might push me in the right direction.
James
