Depends on CUCM version, assuming appliance based CUCM common device config will be used, from CUCM feature guide under EM section:
At the Softkey Template field, choose the appropriate softkey template. The softkey template determines the
configuration of the softkeys on Cisco Unified IP Phones. Choose None if you want to use the softkey profile
that is configured in Common Device Configuration.
HTH,
Chris
