dhcpd.conf showing [FAILED]
premavardhan
Hi Friends,
           I have a problem in dhcpd.conf file. If i enable the option for TFTP server as 150. The dhcp server is not starting and showing [FAILED].
           But if i remove or comment that line then it will work goog, showing [OK].
           Actually my work is to configure Cisco IP Phone 7960. When the phone  powered on it will ask DHCP server to assign an IP address. As a result  the DHCP server assigns an ip address let it be 192.168.1.4. The DHCP  servers ip address is 192.168.1.162.
          Now i am trying to run tftp server in the same machine 192.168.1.162.  But i am unable to enable this tftpserver address in dhcpd.conf file.
         Can any on help me to solve this problem.
PVR.
In the dhcpd.conf i see "ption tftp-server code 150 = ip-address;"...without the letter "o"....
Best regards.
Massimiliano Serafino.
