07-13-2015 10:43 AM - edited 03-17-2019 03:38 AM
Hello my name is jerry harris and I have a question on dial-peers busying out.
what causes dial-peers to go into busyout state. we have 3 dial-peers and they all will got into busyout state all at the same or one at a time several during the day. we have been shutting them down sometimes for several minutes then bring them backup before they establish connection again. will the keepalive timer's cause this issue ? is their any other time's that i need to check that may be causing this issues.
Jerry Harris
Apriva ISS
Solved! Go to Solution.
07-13-2015 11:15 AM
Yes, that has to mostly with keepalive timeout. Please check the following;
https://supportforums.cisco.com/discussion/12514401/will-keepalive-option-be-available-voip-gateway-without-cube
http://www.cisco.com/c/en/us/td/docs/ios/12_4t/12_4t11/FeatBOS.html
07-13-2015 11:15 AM
