Showing results forĀ
Search instead forĀ
Did you mean:Ā
cucm service manager not running
Jose Afonso
Hello I have issues with cucm version 8.6 ; cucm service manager not running, tried utils service start Service Manager without success
Manish Gogna
Hi Jose,
Can you provide the output of the following in a notepad file:
utils service list
show status
utils core active list
utils diagnose test
You may need to run the recovery iso to fix this issue, it can be downloaded from the following link
https://software.cisco.com/download/release.html?mdfid=283782839&flowid=45898&softwareid=282074294&release=8.6%282a%29&relind=AVAILABLE&rellifecycle=&reltype=latest
Also, check the following to identify if there was an unclean shutdown of this server
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/116717-trouble-cucm-shutdown-00.html
Manish
- Do rate helpful posts -
Hi Manish,
we had power issues that affected the Publisher, by physically shutdown the server and power it up have bring the Publisher Up to service.
Now we are facing database replication issues!
do you know the commands to fix database replication?
Thank you very much for responding.
Jose
Hi Jose,
I would recommend running a file system check and repair using the recovery iso as improper shutdowns can lead to file system corruption and cause issues like the one which you faced.
Manish
