dial peer configuration
edwincharles
hi,
i need some help in the dial peer configuration
we have created the following dial peer to call local and toll free
In local i can call the numbers starting from 1 to 7 but now we have 8 also for local so i want reconfigure so that i can call starting number with 8 also
so i changed  9[1-8]...... but it works for numbers starting with 8 but the pro is we cannot dial the toll free numbers starting 800,
your help will be highly appreciated
thankyou
edwin
voice translation-rule 1
rule 1 /^9/ /6669/
voice translation-rule 9
rule 1 /\(5.......\)/ /90\1/
rule 2 /^1\(......\)/ /9\1/
rule 3 /\(3.......\)/ /90\1/
rule 4 /\(4.......\)/ /90\1/
rule 6 /\(6.......\)/ /90\1/
rule 7 /\(7.......\)/ /90\1/
rule 8 /\(2.......\)/ /90\1/
voice translation-profile Phone1
translate called 1
voice translation-profile incoming_add_9
translate calling 9
dial-peer voice 1002 pots
corlist outgoing localcalls
description "Local Calls"
preference 1
destination-pattern 9[1-7]......
port 0/0/2
forward-digits 7
no sip-register
dial-peer voice 1057 pots
description "Saudi Arabia 800 numbers"
destination-pattern 9800.......
port 0/0/2
prefix 800
no sip-register
techguy73
Ok Edwin, I'm sure there are several ways of achiving this, I would give this a try, I haven't tested it but am sure it's going to work.
Here is what I'd do:
***I'll keep the 1002 dial-peer as is for 1-7 without a change*******
preference 1
port 0/0/2
forward-digits 7
Plus, I'll add the following dial-peer for 8.
dial-peer voice 1004 pots
preference 1
destination-pattern 9[8][^0][^0]....
port 0/0/2
forward-digits 7
***also leave the tollfree dial-peer as is without a change*****
If this helps, please rate this post.
cheers!
TG
5 Replies 5
techguy73
preference 1
port 0/0/2
forward-digits 7
preference 1
port 0/0/2
forward-digits 7
cheers!
TG
Thank you sir for your response, now i am able to dial nos. starting with 8 and the toll free 800
hi,
but i am not able dial
808.... or 870.... nos
abddandashi
Hello Edwin,
Hope you are doing well, you can use the below destination pattern, if yo have not used it already.
dial-peer voice 1 pots
description "For local calls that do NOT START with 8"
dial-peer voice 2 pots
description "For local calls that START with 8 "
destination-pattern 98[1-9].....
!Keep the same destination-pattern for the 800 numbers
dial-peer voice 3 pots
With the Dial-peer 3 destination patterns will not overlap any more.
Good Luck!!!!!
Dear dandashi,
i am fine , hope ur  fine tooo..,
i tried this but 808xxxx, 870xxx nos dont work
but i tried the following and it worked
dial-peer voice 1001 pots
preference 2
destination-pattern 9[1-8][^0][^0]....
port 0/0/1
forward-digits 7
no sip-register
dial-peer voice 1056 pots
preference 6
port 0/0/1
prefix 800
no sip-register
dial-peer voice 1005 pots
preference 1
destination-pattern 9[1-8]0[1-9]....
port 0/0/2
forward-digits 7
no sip-register
preference 1
destination-pattern 9[1-8][1-9]0....
port 0/0/2
forward-digits 7
no sip-register
