05-22-2017 06:39 AM - edited 03-17-2019 10:23 AM
Hello We are using below mentioned Dial-peer....Current setup we have 001 and 009 for external national/international calls
There will be change in Telco ...but DID range we are going to use will be the same ...once the Telco change out going call will go starting with 0030
Currently: End user dial 0 + 009 + external Number to reach national/international calls.
ToBe: End User dial 0 + 0030 + external Numbers to reach national/international calls
Below are the Dial-peer configure on VGW...we not configured any Route pattern on CUCM
Are the below Dial-peer are good enough or do we need to do changes.
dial-peer voice 100 pots
description ** Voice PSTN **
destination-pattern 0T
incoming called-number .T
direct-inward-dial
port 0/0/0:23
dial-peer voice 110 pots
direct-inward-dial
port 0/0/1:23
dial-peer voice 120 pots
direct-inward-dial
port 0/1/0:23
dial-peer voice 130 pots
direct-inward-dial
port 0/1/1:23
dial-peer voice 140 pots
direct-inward-dial
port 0/2/0:23
dial-peer voice 150 pots
direct-inward-dial
port 0/2/1:23
05-22-2017 07:05 AM
Hi Vijay,
These should be fine if :
- the gateway receives 0+0030 + external Numbers
- and the provider needs to get 0030 + external Numbers
If not, you need to do modifications to remove digits as needed.
Rajan
05-22-2017 05:19 PM
to test this you can use csim start <dialed number> and run debug voip ccapi this way you can simulate the call and see if it hits the intended dial peers.
Please rate if useful
