Dial Peer matching but not routing.
BMaples
I have a SIP Trunk out of CUCM to a VG. Doing a dialpeer debug I see it matching the correct dial-peer but I'm getting a "call cannot be completed as dialed". It's incoming/outgoing SIP to another VG, doing a csim start I see it routed correctly with the destination IP address as the session target IP in the dial-peer, but doing physical test calls the destination IP is the CUCM sub. The customer's router is OLD and cisco doesn't support it anymore so I'm out of ideas, please help!
See attached for debug.
Seems that your VG isn't able to communicate with your peer (130.94.108.180). Check if you can ping it using the source ip configured in your gateway. Its a problem at the other side and someone needs to check why you can establish a connection with it.
Not sure where you got that IP, that subnet isn't in the call flow at all. I can communicate with call manager and the destination IP from the VG in question though.
